  • June 16, 2025, 09:22:41 PM
Author Topic: St 60 Blus head RC  (Read 1041 times)
Offline Terry Bentley
St 60 Blus head RC
« on: September 13, 2016, 01:11:44 PM »
HI can some one help me? I have two Super Tiger 60 Blue head RC engines that have been reworked. The crank close at 65 degrees the exhaust total is 165 open the tuned pipe total is 180 open.that is the info from the guy the reworked them.I would like to know can they be used for control line with a pipe.
Re: St 60 Blus head RC
« Reply #1 on: September 13, 2016, 02:09:41 PM »
With that much exhaust duration they would be difficult to tame to a reasonable rpm range for Cl Stunt.  Put one of them on the bench and run it with a pipe mounted and see haw it runs at about 10,000 RPM.  If it will Reasonably turn a 12.25- 4.0 prop at a steady rpm it might work.
Question:  Was the intended purpose for these engines R/C Pattern, or what?
« Reply #2 on: September 13, 2016, 06:30:06 PM »
Yes it was intended for RC pattern.
« Reply #3 on: September 13, 2016, 06:35:32 PM »
I have had two of them. The ABC 4 port PDP Ring versions-"hot ones". I absolutely would not waste my time using them for control line stunt. They are just too wild. In fact, I sold them because, I thought they were just much too hot for me for RC pattern.
« Last Edit: September 14, 2016, 07:45:49 AM by proparc »
« Reply #4 on: September 13, 2016, 09:25:51 PM »
Control Line SPEED !
