  • July 23, 2025, 12:06:13 AM
Author Topic: What lines are appropriate for indoor stunt?  (Read 893 times)
steven yampolsky
« on: November 13, 2013, 09:37:15 PM »
What line thickness should I use for an indoor stunt model?
Re: What lines are appropriate for indoor stunt?
« Reply #1 on: November 13, 2013, 10:04:07 PM »
 Why wouldn't the normal (outdoor) guidelines apply?
« Reply #2 on: November 13, 2013, 10:43:02 PM »
Steven, if you are thinking, the indoor like Igors Gee Bee, there is a fairly comprehensive thread on it from a while back, perhaps a search would yeild that info about lines, and also about the power system you asked about on another thread?
Offline Igor Burger
« Reply #3 on: November 15, 2013, 11:09:14 AM »
Steven, I use thinnest green spiderwire fishing line, but there are also another makers and colors of similar wire, just be sure that you have line which does not elongate under load, usual flexible lines (nylon) are not usefull. Then you must learn make knots, but that is already another storry :- ))
