  • July 01, 2025, 04:30:34 AM
Author Topic: Nobler ARF Control System  (Read 2968 times)
Offline Tim Stagg
« on: August 12, 2010, 11:54:21 AM »
Guys,
I am redesigning the ARF for electric, and will be refinishing to my own taste etc. Couple of questions::
I realize I need to replace the push rods in the stock Nobler, but does everyone replace the metal bell crank with a 4" Tom Morris or similar??
Also what about the fixed lead outs, it is worth modifying with a sliding unit??
Thanks for the input
Tim Stagg
Offline Zuriel Armstrong
Re: Nobler ARF Control System
« Reply #1 on: August 12, 2010, 12:16:45 PM »
Hi Tim,
I replaced mine with a ARF Nobler set-up available from Tom Morris.  A little work for the belcrank, but worth it in my opinion.  I had to relieve the first rib to prevent binding and open the fuse at the elevator horn/clevis to allow free movement.  Still a good flier over three years later with an old Fox 35.
Zuriel Armstrong
AMA 20932
Offline Garf
    • Hangar Flying
« Reply #2 on: August 12, 2010, 12:38:33 PM »
I flew mine with stock bellcrank and leadouts. I replaced the forward pushrod with a 4-40 rod and the rear with a carbon fibre rod and HD clevises. The stock pushrod/clevises are dangerous.
Offline Will Davis
« Reply #3 on: August 12, 2010, 02:21:20 PM »
Tim,
I uaed a Tom Morris Set, Bellcrank, Pushrods, Horns.. can't go wrong with this stuff, I would not trust anything bu Tom Morris  or my own .. .. The leadouts will work OK, If you are leaving monokote, easy to cut , move and re monokote, not so easy to make adjustable , but a nice option to have as you know ..
Will ..
Will Davis
"Carolina Gang"
Offline Tim Stagg
« Reply #4 on: August 12, 2010, 07:39:06 PM »
Thanks all,
I have already ordered the stuff, since I removed all the covering for a silk span/dope finish, I figured I will redo all the systems including adjustable lead outs, adjustable weight box tom Morris system.
Thanks for your input, it is nice to be able to bounce stuff off our peers
Tim Stagg
Offline John Tate
« Reply #5 on: August 13, 2010, 09:33:20 AM »
Tim.
I used the Tom Morris control system also in my ARF Nobler. I had to change the push rod end at the elevator control horn. The fuselage is not wide enough to handle the way the push rod is bent there. You can will be able tell when you get your system. I moved the leadouts forward per the Line III formula. Now I wish that an adjustable lead-out guide was installed even though that would take mush work in that wingtip.
John Tate
« Reply #6 on: August 13, 2010, 12:29:12 PM »
Only thing replaced on my ARF Nobler was leadouts and bellcrank.  On it's fourth engine.  Using it as a test bed.  No cowl as I didn't want to cut it up anymore for the Evo .36.
Offline Tim Stagg
« Reply #7 on: August 13, 2010, 07:21:01 PM »
Thanks John and Doc.
John see you this weekend....I hope
Tim Stagg
