This plane has been under construction roughly for 3 years. No, it's not mine, it's my grandfathers. This plane was originally going to be his weapon of choice for the NATS last year, but he didn't get it finished in time. Also, the plane was coming out heavy, so he stripped down the surface, and began refinishing it. At some point, he decided to add some wingspan to a stock Staris to accomodate the heavier weight. Then, he put the plane on a diet, and made some modifications to the airframe. He cut into the foam wing and pulled out the center section. My grandfather then put in wood and geodetic half ribs to strengthen it up again. He did the same with the stab and elevators since that was foam too. I don't have the number handy, but he saved approximately 8-10 ounces. I was concerned about the strength of the wing but after it's first flights today, I am no longer concerned.
So the final weight is 68 ounces with the wingspan up to 60". Wing area came out to 670. Grandpa made the flaps a little bit bigger as well. Power is a PA 51, that drinks gas like an old buick. 7 ounces of fuel = 5:40 second run time, so he is now making a custom tank to replace the modified plastic tank he had in there already.
I flew it on the 3rd flight, and he has a really good airplane in his hands!! The only trim suggestion I made to Grandpa was take out half the nose weight to make it turn just a little sharper. BTW, the only trim adjustments made so far was adjusting the trim tab to get the wing level!
