  • July 19, 2025, 05:22:29 PM
Author Topic: New RingMaster Deluxe  (Read 8142 times)
Offline Allan Perret
  • Proverbs
« on: October 15, 2010, 05:54:14 AM »
Ever since Randy Powell posted pictures of his first RMD I knew I was going to build one.  It was the coolest profile I had ever seen.   I ordered plans and laser ribset from Pat Johston, but was busy with other projects and put it on the back burner.  Randy lost his first bird to a failed bellcrank and promptly built a second RMD.  When I saw that, it relit the fires.  Everything else I had going at the time was shoved to the back burners.  I started this project the last week of July, finished it yesterday.  There is a construction thread on the "BrotherHood of the Ring" site with lots of pictures showing the build process.  Couple of unique features, the gear is a custom lamination from purplehart veneers, the elevator pushrod is in a tunnel inside the fuse,  transparent finish using Pete Petersens methods that were published in StuntNews about a year ago.  The weight of the finish was about 4.1 oz (normally 10+ for me on a bird this size).  Total weight 48.6 oz,  area 615",  wing loading 11.3.  AeroTiger36 and Randy's 40 size pipe.   I am off to Baton Rouge for the contest this weekend, may put it up for the first flight at the practice session this afternoon.  Big thanks to Randy Powell for sharing his design and help with the build process...
Allan Perret
AMA 302406
Slidell, Louisiana
Re: New RingMaster Deluxe
« Reply #1 on: October 15, 2010, 06:46:57 AM »
NOW THAT is KEWL !!!!
Very Nice! H^^
« Reply #2 on: October 15, 2010, 09:37:38 AM »
Allan,
Man, the final looks very cool. I'm anxious to hear how it flies. How did the balance come out? With a light engine like you're using (versus the boat anchor 40VF I used) should put the balance spot on.
Pete would be proud of the finish.
Offline Elwyn Aud
    • Inferalandings Photo Page
« Reply #3 on: October 15, 2010, 09:51:32 AM »
That's a real stunner. Still has a lot of Ringmaster flavor in it especially when viewed from the side.
Offline Peter Ferguson
« Reply #4 on: October 15, 2010, 10:50:32 AM »
Great job. thats very inspiring. I'm sure it will fly as nice as it looks.
Peter Ferguson
Auburn, WA
« Reply #5 on: October 15, 2010, 11:12:52 AM »
So Pete, when are you starting yours?   ;D
Offline Dalton Hammett
« Reply #6 on: October 15, 2010, 11:26:23 AM »
Very Sharp looking plane..........
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
« Reply #7 on: October 15, 2010, 12:12:38 PM »
I can't stop looking at the finish. I like the way the wood grain shows thru.
Did you dye the silkspan yellow then just put on clear dope?
Offline Jose Javier Rodriguez
  • Control Line forever.
« Reply #8 on: October 15, 2010, 12:29:32 PM »
Oh! Rigmaster a large project ... very nice ;D ;D #^ #^
« Last Edit: October 16, 2010, 02:33:14 AM by Jose Javier Rodriguez »
« Reply #9 on: October 15, 2010, 02:03:27 PM »
Now, that's what i'm talking bout!!!
Offline JamieHolford
« Reply #10 on: October 15, 2010, 02:30:53 PM »
Looks real good!!! Hope to see it tomorow!
« Reply #11 on: October 15, 2010, 02:46:07 PM »
Since Allan is getting ready for a contest, I'll answer. The finish is based on Pete Peterson's method. It's covered with polyspan on the wings and I believe silkspan on the rest. Clear built up then shot with clear tinted with Kandy Koncentrate. That gives the see through colors. I know that Allan shot clear lacquer on top and is still contemplating shooting a catalyzed clear on top to protect it.
Offline Tom Niebuhr
« Reply #12 on: October 15, 2010, 02:51:03 PM »
Great looking airplane Allen. I wish I was going to Baton Rouge to see you and the airplane... Maybe next year. Right now my priority is to get back to VSC next March.
AMA 7544
Offline Matt Colan
« Reply #13 on: October 15, 2010, 04:11:38 PM »
WAY COOL!!!!!!!  What motor is that?
« Reply #14 on: October 15, 2010, 04:22:28 PM »
I'm kinda planning on building an RMD, to go with a K&B 40 I have.
But it's not going to look nearly that nice, I can guarantee you that.
Offline George Grossardt
« Reply #15 on: October 15, 2010, 08:16:16 PM »
That is absolutely beautiful.  Have a blast with it.
« Reply #16 on: October 15, 2010, 08:28:05 PM »
Thanks Randy for the info.
  • Proverbs
« Reply #17 on: October 15, 2010, 09:20:21 PM »
Oh! que gran proyecto de Rigmaster... muy bonita ;D ;D #^ #^
huhh ?
Translation please...
Allan Perret
AMA 302406
Slidell, Louisiana
  • Proverbs
« Reply #18 on: October 15, 2010, 09:24:43 PM »
Matt:  You dissapoint me, go back and read the text.   What, you can't stop looking at the pictures ??
Allan Perret
AMA 302406
Slidell, Louisiana
  • Proverbs
« Reply #19 on: October 15, 2010, 09:51:54 PM »
Randy was mostly correct with his reply about the finish.  However I did vary from Pete's method a little.  After covering, Pete built up base with clear dope,  then sprayed on the tinted coats.   I included the tint in my brushed on coats while filling the weave of the polyspan on the wings and building a base on the rest of the surfaces (silkspan like Randy said).  Then I also tinted the sprayed on coats.  The tint comes from House of Kolor.  About $28 for an 8oz can (online), buts thats enough to do about four planes.  I only used 1/2 oz tint in a 20 oz batch of clear dope/thinner, for both the brushed and sprayed coats..
I used Randolph's non-taut clear dope(#1690) with Finish Pro lacquer thinner (slow) and Randolph's retarder from start to finish.  Red and blue trims colors is Brodak dope with the same thinner & retarder..  Be warned, dope/lacquer can be some finiky stuff.  I had blotching, crazing, and blushing along the way.  Proceed with caution.  I do not think it was from the thinner I used,  but I have no other clues as to why.   May try using Randolph's with the next one.  I love doing the dope and tissue part, but what comes after that scares the hell out of me...
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Matt Colan
« Reply #20 on: October 16, 2010, 07:41:37 AM »
Sorry, Allan, I was so anxious to look at the pictures, I only very quickly skimmed through the text.  My bad.  :P
Offline Elwyn Aud
« Reply #21 on: October 16, 2010, 08:59:07 AM »
huhh ?
This is the best i could get from Babelfish. I guessed Portugese. "Oh! that gran proyecto of pretty Rigmaster… muy"
Oops. I just noticed he modified his message to English. Babelfish didn't do too bad though.
Eric Viglione
« Reply #22 on: October 16, 2010, 09:28:11 AM »
Great job Allan!
Kudo's to Randy Powell for taking the Ringmaster design up to a whole new level, and big slap on the back to Allan for great execution and finish.
Looking forward to flight reports.
EricV
« Reply #23 on: October 16, 2010, 10:13:14 AM »
No room on the bench now but I could get one done for next year.
Peter Ferguson
Auburn, WA
« Reply #24 on: October 16, 2010, 06:57:56 PM »
I have just cleaned up the slobbers drooling over your RMD.   LL~ LL~ H^^
« Reply #25 on: October 16, 2010, 09:18:44 PM »
NICE job Allan!
