  • July 07, 2025, 08:30:14 PM
Author Topic: New planenew build.  (Read 2859 times)
Offline Andrew Saunders
  • 2013 Nats
New planenew build.
« on: April 21, 2013, 06:33:37 PM »
New plane new build. This is the plane I've been learning to build and scratch build on.
Offline Paul Wescott
Re: New planenew build.
« Reply #1 on: April 21, 2013, 07:16:34 PM »
Which design is that?
Online Paul Taylor
« Reply #2 on: April 21, 2013, 08:08:34 PM »
Look Great!!!!  What engine are you going to use?
You might want to take that bend out of the rudder.
Do you fly in the other direction?
« Reply #3 on: April 22, 2013, 05:54:49 AM »
I see someone else caught the rudder angle.  Looks like you are listening and doing. H^^
Offline Mike Starrett
« Reply #4 on: April 22, 2013, 06:52:57 PM »
It's a combination of these two planes (modified TF Tutor and a more modded TFT).  He is using an LA 46 and the rudder is the wrong way because it will be adjustable and that just happens to be how it's hanging on.
Online Paul Taylor
« Reply #5 on: April 23, 2013, 08:59:24 AM »
Thanks for clearing up the rudder question. That will work.
Is that a scaled up Tutor?  Can't go wrong with those blue engines but a lot of engine for the smaller Tutor.
IMHO.  H^^
Offline ray copeland
« Reply #6 on: April 23, 2013, 10:48:24 AM »
That looks great Andrew!  My first couple of builds didn't turn out near that good, i look back at a few of my first planes (Ringmaster, Twister) and think why would i have done it that way?
  • 2013 Nats
« Reply #7 on: April 24, 2013, 05:52:11 PM »
Thank you Ray. Its turning out awesome thanks to a great builder and teacher. Learned allot of new tricks during this build.
  • 2013 Nats
« Reply #8 on: May 02, 2013, 07:24:51 PM »
Here's the latest.
Offline Allen Brickhaus
  • ACE
« Reply #9 on: May 04, 2013, 07:48:36 AM »
Looks great, you seem to be getting good help.  Say hello and thanks to Mike.
Allen Brickhaus
  • 2013 Nats
« Reply #10 on: May 09, 2013, 04:17:03 PM »
Had its maiden flight yesterday . Made adjustments two times and Flies great!!! Very solid and stable flying plane. Cant wait to learn and get real confident in flyin the whole pattern. Mike from My club ( SKYLINERS) took it up for the maiden flight. Had a big smile on his face.
Offline Crist Rigotti
« Reply #11 on: May 09, 2013, 05:09:11 PM »
Mike,
Did you publish a design called the Eliminator?  It was a windy weather airplane with an OS 25VF in it?  I almost built one of those.
« Reply #12 on: May 09, 2013, 08:39:05 PM »
Mike,
Yes, I did.  The wing in Andrews plane is the same wing as the Eliminator.  Just in the same nose to tail ratio as a Tutor.  But then, so was the Eliminator.  Probably far from the best setup but I always liked it because of it's stability.
  • ACE
« Reply #13 on: May 09, 2013, 08:47:46 PM »
Eliminator, great model.
Offline Ward Van Duzer
« Reply #14 on: May 11, 2013, 08:48:54 AM »
Guess I'm old fashioned, but I never understood why some folks will go to all the fuss to add an inboard tripler on a profile and not tie it into the wing???????????????
W.  ???
Online Steve Helmick
« Reply #15 on: May 11, 2013, 05:15:32 PM »
W.  ???
Ward-O...Yup!  y1 Steve
