  • July 22, 2025, 11:27:25 AM
Author Topic: New plane  (Read 4320 times)
Offline SteveMoon
    • www.ultrahobbyproducts.com
New plane
« on: June 04, 2009, 07:19:11 AM »
I've finished my new plane for the 2009 (and hopefully more) season.
For the first time in 5 years I won't be flying a Saturn at this years Nats.
The new one is called the Furias 96. I started with a 96% version of my
brother Doug's Furias and then made a couple of adjustments to the
numbers and ended up with the Furias 96. It has 650 sq. in. of wing
with a 59.25" span. Power is the new OS 56 FS-A, and it has plenty of
power. It has no problem pulling this plane around, even though it is
about 5 oz. over it's target weight. It still performs nicely, and after 14
flights so far I am quite happy with the results.
Later, Steve
Re: New plane
« Reply #1 on: June 04, 2009, 08:00:26 AM »
Very Nice !!!!
I like the air scoop way kewl ! #^
Offline Crist Rigotti
Re: New plane
« Reply #2 on: June 04, 2009, 08:14:56 AM »
Nice airplane Steve.
Re: New plane
« Reply #3 on: June 04, 2009, 08:33:30 AM »
It looks really good Steve. Nice lines.
Eric Viglione
Re: New plane
« Reply #4 on: June 04, 2009, 09:04:00 AM »
Hi Steve -
Looks great! #^ Only 31 days left till I get to see this puppy in person. Man time starts to feel short when you start to count how many days, or weekends,  or worse yet- potential practice sessions, are left until the Nats. Subtract a couple sessions for rain outs, etc. and... Eeeek!  :o
EricV
Offline Scott Hartford
Re: New plane
« Reply #5 on: June 04, 2009, 09:32:48 AM »
Great looking plane! What prop is that?
Re: New plane
« Reply #6 on: June 04, 2009, 09:57:13 AM »
Great looking plane.  DOC Holliday
Re: New plane
« Reply #7 on: June 04, 2009, 10:02:13 AM »
Looks great!
Offline RC Storick
Re: New plane
« Reply #8 on: June 04, 2009, 10:49:19 AM »
So Steve what was the target weight and what did it end up?
Offline james dean
  • Rebel with a cause AMA 467575
Re: New plane
« Reply #9 on: June 04, 2009, 11:15:09 AM »
Hi Steve,
B-e-a-u-t-i-f-u-l   lines and trim!    Is there a certain "Bearish" influence to be detected there?  I love it!! #^
Offline SteveMoon
Re: New plane
« Reply #10 on: June 04, 2009, 12:29:32 PM »
The prop is an Eather 12 x 4 that has been repitched to almost 6.
The target weight was 64, but it's a good 5 more than that. I tried
a different primer this time. It filled great, but Doug and I both suspect
that it adds quite a bit of weight in the process.
Re: New plane
« Reply #11 on: June 04, 2009, 02:42:04 PM »
Steve, tell us about that new O.S. 56 FA. Boy, this is where Youtube would really come in handy!!!
Offline Richard Grogan
Re: New plane
« Reply #12 on: June 04, 2009, 03:35:11 PM »
Sweet! And a great color scheme to boot!  H^^ The only thing missing is those "Moon Eyes"! LL~
« Last Edit: June 04, 2009, 05:32:26 PM by Richard Grogan »
Long Live the CL Crowd!
                  AMA 85745
Offline Bradley Walker
    • The Urban Rifleman
Re: New plane
« Reply #13 on: June 04, 2009, 05:06:33 PM »
Powerful and smokes like a freight train (which is good).
-George Bernard Shaw
Offline SteveMoon
Re: New plane
« Reply #14 on: June 04, 2009, 05:36:03 PM »
Yep, the new OS 56 FS-A is really powerful. The advertisements
claim an additional 20% hp over the previous generation OS 52 FS,
and I don't doubt it. With the OS 52 I was using Powermaster YS 20/20
fuel (20% nitro). I always used that fuel, no matter the conditions
and it always used the same amount. With the 56 I have cut down
the nitro to about 15%. The motor just ran too hard with the 20%
nitro.
The prop is slightly bigger. With the 52 I used a 13 x 4 Eather 3 blade
that was cut down to 11.75" and repitched to about 5.5. With the 56 I'm
using a 12 x 4 Eather 3 blade repitched to about 6. I have 2 other props
to try out that are a bit longer, but haven't had a chance to yet.
The motor runs consistenly throughout the pattern, just as the 52
always does. It's pretty much set it and forget it.
Later, Steve
Offline Allan Perret
  • Proverbs
Re: New plane
« Reply #15 on: June 04, 2009, 05:38:28 PM »
Looks great, nice trim scheme.
What is weight of that OS56.
Was curious how it compares with Saito 62 c/l, which I have.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline SteveMoon
Re: New plane
« Reply #16 on: June 04, 2009, 05:39:37 PM »
Richard: There is a small set of Mooneyes on each of the landing
gear skirts. All of my planes have a set somewhere on them.
Offline SteveMoon
Re: New plane
« Reply #17 on: June 04, 2009, 05:43:45 PM »
The motor weighs 16 oz. including the muffler. The muffler
is very nice, it is adjustable on 3 different axis. I've also
replaced the carb with a UHP manifold/venturi setup.
Check it out here: http://www.os-engines.co.jp/english/line_up/fsalpha56/index.htm
Re: New plane
« Reply #18 on: June 04, 2009, 06:00:37 PM »
Great looker there, Steve!  I especially like the nose shot, it looks like it's about to chew you up!
Blessings,
Will
Offline Martin Quartim
    • StuntHobby
Re: New plane
« Reply #19 on: June 04, 2009, 09:06:44 PM »
Hi Steve,
Real nice model you got there! Good luck at the NATS
Martin
Re: New plane
« Reply #20 on: June 04, 2009, 09:12:52 PM »
You need a set on each side of the turtledeck, right behind the canopy! #^
                  AMA 85745
Offline Matt Colan
Re: New plane
« Reply #21 on: June 05, 2009, 01:19:43 PM »
Lookin Good Steve!!!  Good luck at this year's Nats  H^^
Re: New plane
« Reply #22 on: June 05, 2009, 01:56:32 PM »
I would like to see Steve use the smaller venturi.  He simply does not need the power...  The run of the OS engine is very impressive.
Re: New plane
« Reply #23 on: June 05, 2009, 03:34:09 PM »
Steve:
Furias reeks of awesomness!  Couple of quick questions:
* How much fuel, and do you use pressure, uniflow, you know the usual questions.
* You said you cut back from 20% to 15% nitro - do you think you will go to 10%?
Offline SteveMoon
Re: New plane
« Reply #24 on: June 05, 2009, 04:48:56 PM »
Dennis: I'm using the always reliable Sullivan plastic tank plumbed
the same way we always do it; pressure line u-turned to the front.
I'm running with pressure and using about 3.5 oz. per flight. This is
what I was using with the OS 52 also. So far, it seems really good
on 15%, but we'll see if I need to cut back any up in the good Muncie air.
With the 52 I never changed nitro amount. Once I found what worked
I always stayed there. It was not uncommon for me to go an entire
contest weekend without touching the needle, changing nitro, or
changing the amount of fuel used per flight.
Re: New plane
« Reply #25 on: June 05, 2009, 05:02:42 PM »
Sheeesz that souns like...an ELECTRIC!!!!!   :o  n~  8)   LL~
