  • July 13, 2025, 07:42:56 PM
Author Topic: Never had this happen b4  (Read 1643 times)
Online Paul Taylor
« on: August 31, 2014, 07:29:45 AM »
I was just tacking something up and CA'ed the wood to my finger. That always happens but as soon as I feel it I pull it off. Well last night I could not pull it off. I did not feel it and held it in place then felt it start to burn. It felt like it was going to pull skin off. So I tried soaking it in acetone. No go!  Put it on the belt sander. That did the trick. 😜
Re: Never had this happen b4
« Reply #1 on: August 31, 2014, 07:54:23 AM »
Paul,
They make a "release" agent just for things like that. The agent, simple liquid chemicle, can also be used to remove any part attached with CA.
Comes in handy.
Online Paul Taylor
« Reply #2 on: August 31, 2014, 07:54:48 AM »
Pics
« Reply #3 on: August 31, 2014, 12:11:09 PM »
Hi Paul,
The belt sander sounds  a little risky!
For what it's worth, 15 to 30 seconds in nitro methane will soften CA so it can be eailsy pulled apart.
In fact I believe that the comercial de-bonder sold by Tower and others is only Nitro Methane!
Safer than a belt sander!
« Reply #4 on: August 31, 2014, 12:44:45 PM »
You can just wait a while -- CA only bonds to skin for a while, then it peels off.
When I do something like that I trim the hunk down with a modeling knife (TRIM, don't try to cut it off), or maybe sand it a bit with a HAND sanding block.  Then later in the day or the next morning I pull it off.
« Reply #5 on: August 31, 2014, 01:04:39 PM »
Sometimes you can't sand it off if you glue fingers together. I find acetone works better than nitro. Soak a Q tip in acetone and keep pulling the edge as you keep it wet. Don't pull too hard and rip the skin. Takes a few minutes but it works.
Offline Zuriel Armstrong
« Reply #6 on: August 31, 2014, 03:02:29 PM »
Holy Crap Paul!!!
Hey Ya'll watch this!!!
I'm going to send you some debonder.
Zuriel Armstrong
AMA 20932
« Reply #7 on: August 31, 2014, 03:11:55 PM »
I woulda thought there'd be an iPhone APP for that.  LL~ Steve
Offline WLGeorge
« Reply #8 on: August 31, 2014, 03:21:00 PM »
Next time try a fingernail file instead of the belt sander. Not near as much chance of getting a new nickname like Nubby, Klutzo or my personal favorite Three Finger Jack.  Where I work they call me Dangit but I don't wanna talk about it:-)
Online Paul Taylor
« Reply #9 on: August 31, 2014, 04:22:14 PM »
There is. It's called stunt hangar.
« Reply #10 on: August 31, 2014, 06:33:48 PM »
thats all well and good except that will be the night the wifey feels amorous,,, then what LOL
Offline Dick Pacini
« Reply #11 on: August 31, 2014, 08:04:36 PM »
It all depends where you stuck the wood... >:D
AMA 62221
« Reply #12 on: September 01, 2014, 12:46:17 PM »
I had a nearly full bottle of thin "buildit" that got stuck in my hand....thing is, I fell backwards on my stool, and was grabbing everything trying not to break the part I was gluing. Well, I couldn't get the bottle out of my hand...all 4 fingers and my thumb were stuck. This would never have happened if the applicater tip hadn't come off....talk about getting hot...!!! After I finally got to my feet, I straight away got my other hand stuck. I started to pry my shoe off....then I thought better of it. We used nearly a whole bottle of my wife's fingernail polish remover before the plastic turned loose. The whole label was stuck in my right palm. LL~
