  • June 17, 2025, 10:33:48 PM
Author Topic: Need Profile Recomendations for OS46FX  (Read 1109 times)
« on: March 01, 2018, 01:01:42 PM »
Would any of you out there know of a good profile kit that would be big enough for an OS46FX?  I really like the Cardinal but it seems a bit small and I don't think I can make up for the added weight of the FX.  I don't know what is really out there.  Are there short kits or wing kits available?   My biggest problem is not having a place to properly jig a wing of this size until later this year.  Any advice would be greatly appreciated.
Offline Jim Carter
Re: Need Profile Recomendations for OS46FX
« Reply #1 on: March 01, 2018, 01:42:26 PM »
Would any of you out there know of a good profile kit that would be big enough for an OS46FX?  .... Any advice would be greatly appreciated.
Although I'm no "expert", I suppose any of the newer 40 sized kits would do.  Just curious, although you mentioned kit, are you experienced in scratch building?  If so, allow me to recommend a plan for a model called the Big Tiger designed by a fellow named Claus Mikias.  There's a fellow selling the plan on E-Bay if you want to look it over.
I am so stuck on this plane that my friends think I'm crazy.  I've built six of them so far, two of which I still fly, the others I've sold plus building 3 separate wings that I've sold for guys to use as replacements on their planes.  Granted I did make a couple of minor changes from the original plans but they were minimal at best.
Offline Perry Rose
« Reply #2 on: March 01, 2018, 01:56:41 PM »
Mike Griffin can get you a kit of the Mo' Best. 58 inch wing. Top notch balsa and parts, flys very well.
Offline peabody
« Reply #3 on: March 01, 2018, 02:00:24 PM »
The Cardinal will work well....
Offline Dalton Hammett
« Reply #4 on: March 01, 2018, 02:04:37 PM »
I agree there are a number of great large profiles available and Walt Umland  builds great kits as well as Pat King.   Pat has a line of various size Flite Streaks for different size engines.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline rich gorrill
« Reply #5 on: March 01, 2018, 02:05:01 PM »
I think the Pathfinder is a little bigger than the Cardinal from Brodak's. As mentioned the Mo Best is a great choice,
Offline jim ballard
« Reply #6 on: March 01, 2018, 02:08:38 PM »
Might look at this one. Profile Cardinal 55" span and 555 sq in area.
http://brodak.com/profile-oriental-kit.html
I'm no expert but looks like it might fit your plan.
Tempting fate and gravity one more time....
Jim Ballard
Blackwell, TX
AMA 62811
Offline Walter Hicks
« Reply #7 on: March 01, 2018, 02:14:32 PM »
Hands down best flying kit would be the Imitation, will fly way better and have more wing area and be lighter :)
« Reply #8 on: March 01, 2018, 02:34:44 PM »
I looked at a couple of them and it does look like it might handle the extra weight and HP of the FX and quite frankly, it looks like something I would design.
« Reply #9 on: March 01, 2018, 03:00:44 PM »
How about a "Berserker"...PAMPA plans...I believe it used a foam wing. It was designed for a ST .60 but the .46FX weighs about the same and puts out at least as much "power" if you run around 4" pitch props.  H^^ Steve
Offline Vincent Judd
« Reply #10 on: March 01, 2018, 05:42:17 PM »
Agreed.  Go get yourself an Imitation kit from Mike Griffin.
