  • June 20, 2025, 07:30:37 PM
Author Topic: Need engine  (Read 3348 times)
Offline JIM Nordin
Need engine
« on: March 29, 2015, 06:38:02 PM »
Not sure if this is the right place to,post this.  I have a Brodak bearcat plans comeing and plan on putting her together ASAP .  Does anyone know where I can find one new engine or a decent used one . I found a evolution 40 CL but know nothing about them
Jim
Offline Douglas Ames
Re: Need engine
« Reply #1 on: March 29, 2015, 07:43:54 PM »
Classifieds on this forum, or eBay. Sure it's not an Evo .36?
AMA 656546
Offline JIM Nordin
Re: Need engine
« Reply #2 on: March 29, 2015, 08:16:40 PM »
Just read up on the evolution and its a 36 . That's on the small side of the recommended size but I buils super light planes  . Inn think I'll order one and a 40 RC  for a RC plane I'm building
Thanks Jim
Re: Need engine
« Reply #3 on: March 29, 2015, 08:35:03 PM »
I've seen a couple of those airplanes fly with LA46's and it seemed to be an Ideal combination.  That would be my first choice and an ST46 would be my second.  I think you'll be disappointed with the Evolution 36.
Offline JIM Nordin
Re: Need engine
« Reply #4 on: March 29, 2015, 08:53:05 PM »
Randy I think your right
Re: Need engine
« Reply #5 on: March 29, 2015, 09:47:12 PM »
I want to just send you to Tower Hobbies with directions to just get an LA 46 -- but the CL version is discontinued, and the RC version is currently out of stock!!
Da Bay has some LA 46's, including "new in box", but they're all RC -- you'd have to scratch for a venturi.
Does Enya have something right sized?  Who's selling Enya engines?
Re: Need engine
« Reply #6 on: March 29, 2015, 09:55:03 PM »
Getting a venturi for an LA46 is a no brainer.  Jim Lee, Randy Smith, and many others provide these.
Offline JIM Nordin
Re: Need engine
« Reply #7 on: March 29, 2015, 10:09:45 PM »
The local Hobby shop has a couple of LA  46 RC  I'll go pick one up in the morning
Thanks for the help guys
Jim
Offline Perry Rose
Re: Need engine
« Reply #8 on: March 30, 2015, 04:42:09 AM »
If you are referring to the Pat Johnston designed Bearcat by Brodak with a full fuselage I have one with the LA.46 and it works very well. I hope you are an expert scratch builder as the plane is challenging to build from the kit. It's really nice when completed. You will need a very long tongue muffler as the cowl is quite large.
Offline JIM Nordin
Re: Need engine
« Reply #9 on: March 30, 2015, 07:15:26 AM »
It's the one with a built up fuse and yes I concider my ,self a expert builder I have had my own design's show upin a couple of magazine RC not control line .  What a surprise
Are the OS LA Engines that are Blue are they worth getting !
Thanks JIM
Online RC Storick
Re: Need engine
« Reply #10 on: March 30, 2015, 07:47:16 AM »
Thanks JIM
Yes and if its RC you can get a spray bar and venturi from Randy Smith or Jim Lee
Offline JIM Nordin
Re: Need engine
« Reply #11 on: March 30, 2015, 09:39:25 AM »
Thanks Robert yes there RC  . FYI I picked up a P51 B profile  I'm together so I can get flying ASAP
Jim
Online Geoff Goodworth
Re: Need engine
« Reply #12 on: March 30, 2015, 07:40:44 PM »
Jim, the OS factory conversion parts are available from Tower.
You need—
The FP 40 venturi, OS Part No 23312000, Tower Stock No LXCX05,   $11.99
OS 20-25FP-S NVA, OS Part No 22311000, Towqer stock No LXCR49, $13.49
I suggest that you also order the FP 20/25 Venturi, OS Part No 22312000, Tower Stock No LXCW99, $9.49.
The FP 20/25 venturi is worth a try but probably too small. However, we have several successful LA 46 installations at our club that used the small—and no longer available—FP 35/40 venturi. Bore the FP 20/25 venturi to 17/64" dia and you have an equivalent to the small FP 35/40 venturi.
All this stuff bolts straight into the front of the crankcase without any drilling of crankcase or venturis—easy!
Offline eric rule
Re: Need engine
« Reply #13 on: March 30, 2015, 08:10:08 PM »
RSM Distribution carries in stock venturis and ST needle valve assemblies for the following engines:
OS 35,40 FP
LA 25
LA 46
ST 46
ST 60
Offline JIM Nordin
Re: Need engine
« Reply #14 on: March 31, 2015, 06:51:35 PM »
Ok I want to thank all,of you guys for all the advice and information I ended up buying a new OS LA 46 for $79 and a new evolution NX 46 for $99 .  Not sure if that's a decent price or not . I'm still in the market for a engine for a Brodak profile P51 B that will go together before the Bearcat
Again thanks everyone
Jim
