  • July 07, 2025, 07:26:20 PM
Author Topic: Oriental Plus building (New pics 11/30)  (Read 12151 times)
Online Matt Colan
Re: Oriental Plus building (new pics 10/22)
« Reply #50 on: October 31, 2009, 05:17:44 PM »
Matt can you post some pics of the pipe tunnel. That is very interesting idea.
Yeah, I'll try to post pics tomorrow, since once again, I had to get back home for dinner.
Today, we cut off the excess plywood, and now have a nice looking pipe tunnel.  We spent about an hour thinking of ways to mount the landing gear because in order to clear a plastic tank, we had to go from a 1 inch header to a 1 1/4 inch header, and now the normal landing gear mount isn't any good.  We thought of trying the chipmunk landing gear, but that wasn't any good, the normal landing gear is too narrow because we widened the fuselage for our original plan to power this plane with an OPS 40.  We ended up deciding to use SV-11 landing gear from Vic Macaluso's SV-11.  It has a wider stance and is wider where you mount the landing gear.  I'm also going to use the fiberglass SV-11 wheelpants for this plane also, so it'll have an original twist to it.
I also got the tail block on and am somewhat ready to glue the rudder on.
Online Matt Colan
« Reply #51 on: November 01, 2009, 03:46:06 PM »
Ok here is a couple pics of the pipe tunnel, I'll provide more details when I get home after dinner but they should be pretty self explanitory
Online Matt Colan
Re: Oriental Plus building (new pics 11/1)
« Reply #52 on: November 01, 2009, 05:52:22 PM »
Ok here is how I made the pipe tunnel.  1/64 plywood flexes very easily so you can wrap it around into a tunnel with very little trouble.  We marked the length of the pipe tunnel, and cut the plywood.  Then we just wrapped it around nothing, placed it in the fuselage and tack glued it in the front former and a piece of wood we glued on the wing.  When the glue was dry, I ran Elmer's white glue where the plywood joins the fuselage sides, let it dry and cut the excess off.  And there you go, a pipe tunnel.  Grandpa got this idea from Vic Macaluso who passed it on to me.
Today we spent quite a while making up the landing gear platform, where we have a hole for the pipe and then 3/8 clearance from there up.  Didn't get to mounting the gear yet since it actually took quite awhile.
Offline steve pagano
« Reply #53 on: November 01, 2009, 11:18:26 PM »
Hi Matt
   Lookin real good !!!
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Offline Bryan Higgins
« Reply #54 on: November 02, 2009, 12:03:12 PM »
Looking good Matt , It should be a good flyer. D>K
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
« Reply #55 on: November 02, 2009, 12:20:06 PM »
Ditto on the looking good.  It is amazing how much time can be spent on something simple.
« Reply #56 on: November 02, 2009, 02:25:47 PM »
     Makes me wanna start building again!!!!!  But im drowning in work and school HB~>
Any chance you'll be at Flushing next season ?
A.M.A. 820-823
Online Matt Colan
« Reply #57 on: November 02, 2009, 03:18:15 PM »
Hi Steve,
We may go to Flushing if the contest falls on the same weekend as the Jones Beach Air Show, which is how we went last year, but didn't go this year.
Hopefully the contest is on the same weekend as the airshow, then chances are we'd make a trip down there.
« Last Edit: November 02, 2009, 04:05:43 PM by Matt Colan »
Online Matt Colan
« Reply #58 on: November 13, 2009, 07:41:11 PM »
Spent tonight working on the landing gear, aluminum shavings were all over my hands.  Just trying to dress up this one bad spot, got it pretty good now.  Also I watched, Beyond the Sea, the Bobby Darin story.
Online Matt Colan
« Reply #59 on: November 15, 2009, 03:25:04 PM »
Update: mounted the landing gear, cut the canopy and slid the rudder on and took some pictures.  I'm at home now, so I can't post them unless Windy fowards them to me so I can post them.
« Reply #60 on: November 15, 2009, 11:35:10 PM »
Keep pluggin away at it Matt!  and keep those pix coming...
Online Matt Colan
« Reply #61 on: November 23, 2009, 05:15:41 PM »
On Saturday, I estimated the weight of the Oriental Plus and the mainframe weighs 27 ounces.  Figure 8 ounces for the motor, another 3 for the header and pipe, 1 for the plastic tank, and ~2 ounces for the landing gear would put the weight of this airplane at...
41 ounces!!!!!  That is with everything covered in silkspan (on the mainframe that is).  Still need to do the fillets and make the cowl.  I am so excited that the plane is that light, I would definitely be able to put a great finish on that airplane and not worry much about weight.  I've been aiming for 48 ounces, and think 46 ounces is easily attainable!
Online Matt Colan
Re: Oriental Plus building (New pics 11/30)
« Reply #62 on: November 30, 2009, 07:07:57 PM »
Ok New pics finally!!!  Since these pictures were taken, I've made the tailwheel, and got the bottom together, the fillets are on, and I was starting to work on cockpit detailing yesterday.
I apologize for the pictures to be a bit on the blurry side, but it is the way it is.
Enjoy the pics  H^^
Edit:  I will be starting a new thread on the finishing of this airplane in the painting and finishing section since I'm not building really building the airplane anymore if you know what I mean
Offline stephen hollier
« Reply #63 on: December 01, 2009, 10:03:01 AM »
Looking good!! Keep up the good work!!
Online Matt Colan
« Reply #64 on: December 01, 2009, 04:00:51 PM »
Thanks Stephen, any update on yours?
« Reply #65 on: December 02, 2009, 10:44:56 AM »
I just returned working on it. I broke my foot so I have been down for quite a while. I will keep you posted on my progress.
« Reply #66 on: December 02, 2009, 02:20:38 PM »
Looks good Matt, Very impressive building skills.
Online Matt Colan
« Reply #67 on: December 02, 2009, 02:32:26 PM »
Thanks Derek, still learning but I'm getting there!!
