  • June 19, 2025, 03:47:18 AM
Author Topic: SPINNER HELP  (Read 1843 times)
SPINNER HELP
« on: August 23, 2006, 05:34:46 AM »
I posted this last night and it must have gotten wiped out in the big crash.
 I am building a postal Perky speed model.The rules call for a 1.5 inch spinner.I am using a ST/.15 motor and it has the small shaft. I have a new Veco 1.5 spinner but the lock nut has to be 1/4-28 on one side and the smaller ST/.15 thread on the other side. Does anyone make a lock nut like this? What is the thread on the ST shaft?  I could use a plastic spinner but the motor is going to be turning 18,000 + rpm and the metal spinner would be much better.
Offline Bob Zambelli
Re: SPINNER HELP
« Reply #1 on: August 23, 2006, 06:15:18 AM »
Ed - I make custon spinner nuts with most thread combinations.
You can call me and tell me exactly what you need.
I have an ST .15 with the small metric thread - If yours is the same, I can use it as a pattern.
Bob Z   610 328 4000, ext 551.
Re: SPINNER HELP
« Reply #2 on: August 23, 2006, 06:52:30 AM »
Bob I will get back to you soon
Ed Ruane
Re: SPINNER HELP
« Reply #3 on: August 23, 2006, 03:48:03 PM »
Bob I just checked the ST/.15 and it is the flat top piston version and I believe they were metric like you said. The number you show has a ext so I would guess it is a work number so I will call you tomarrow. Go ahead and make it.Can you make it from steel not aluminum? A friend made me some 1/4-28 from steel many years ago and they are still in great shape. The aluminum on the small shaft would be a week spot.The motor has a beautiful aluminum spinner but it is only one inch in diameter.
Ed Ruane
Offline bill marvel
  • Lafayette Esquadrille, St. Louis
Re: SPINNER HELP
« Reply #4 on: August 24, 2006, 03:29:28 PM »
Bob
I have similar problem with an OS Max .15.  The OS has a 1/4 X 20 shaft thread.  The Brodak spinner has a 1/4 X 28 front end thread.  If you can send me an address, I'll drop the one I have in the mail to you and you can copy it with the modified threads.
Bill Marvel
Bill Marvel, AMA 793835
Welcome to Stunt Hangar
Offline Marvin Denny
Re: SPINNER HELP
« Reply #5 on: August 24, 2006, 09:04:03 PM »
 Ed, I have a 1 1/2 inch Fox spinner that takes a 10 X 32 screw in the front, and also a 1 1/2 inch Veco that takes a 1/4 X 28 thread up front.  Both backplates have about # 10 shaft holes.
  Could you use either of these?
  E-Mail me at mdenny4@cox.net
marvin Denny  AMA  499
Re: SPINNER HELP
« Reply #6 on: August 25, 2006, 04:43:43 AM »
Marvin thanks but I have a Veco 1.5 spinner with the 1/4-28 thread . The ST/.15 has a small shaft and is metric. I talked to Bob and he is going to make a lock nut with the proper threads in each end. I have a insert for the Veco backplate to make it fit the small shaft.
