  • June 26, 2025, 08:15:02 AM
Author Topic: Veco Tomahawk  (Read 4878 times)
Offline Bootlegger
Veco Tomahawk
« on: June 03, 2013, 11:53:50 AM »
  Where might I find a copy of the original set of these plans?
 Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Mike Anderson
Re: Veco Tomahawk
« Reply #1 on: June 03, 2013, 12:17:48 PM »
AMA Plans service lists a couple of different "Veco Tomahawk" plans, plus the Veco Tom-Tom, plus a couple other 'Tomahawk' plans.
Mike@   AMA 10086
Central Iowa
Re: Veco Tomahawk
« Reply #2 on: June 04, 2013, 08:56:42 AM »
If you go to Brodaks you can get either the Original Tomahawk or the newer Tomahawk plans.   I have both kits in my possession.
Re: Veco Tomahawk
« Reply #3 on: June 04, 2013, 03:27:57 PM »
I built a "Veco" (original) Tomahawk from Brodak plans while a buddy of mine built a "Veco" Tomahawk from plans drawn of kit parts.  The Brodak wing is constructed with slightly different methods.  Mostly very close to the "Veco kit drawings".  A very nice flying smaller profile using a .20FP BBTU, or a .25FP.   Haven't seen one yet with a .25LA, so can't comment other than to say it should fly well.  A Veco .19BB might be a very good choice while a plain bearing Veco .19 wil fly it pretty good.
BIG Bear
RNMM/AMM
Offline Phil Spillman
Re: Veco Tomahawk
« Reply #4 on: June 04, 2013, 06:46:06 PM »
Hi Boot, Please check your in box for a Personal Message!
Phil Spillman
Phil Spillman
Mark_Gerber
Re: Veco Tomahawk
« Reply #5 on: June 04, 2013, 07:34:32 PM »
None of the plans I've seen are completely accurate so I drew my own from a kit.  The Tomahawk wing, when built per the kit, looks like a beautiful I-beamer.  I posted my plans on the Hip Pocket Builders forum http://www.hippocketaeronautics.com/hpa_plans/categories.php?cat_id=71&page=2.
Mark Gerber
Offline 55chevr
Re: Veco Tomahawk
« Reply #6 on: June 04, 2013, 09:26:47 PM »
Veco Tom Tom I had did not fly very well.  It is designed for a .19 engine ... I used a Fox 35 and it was a dog.
Joe
Joe Daly
Re: Veco Tomahawk
« Reply #7 on: June 05, 2013, 08:50:09 AM »
The Original Tomahawk was one of my first profiles that didn't last long.   The newer version is what my son won his first award with.  I also still have an original Tom Tom hanging in the shop that has been flown at the NATS in classic with a Fox .19 that was fast.
Offline George
  • Love people, Use things.
Re: Veco Tomahawk
« Reply #8 on: June 05, 2013, 08:59:53 AM »
Joe
The first larger than 1/2A plane that I flew back in the mid fifties (year, not age) was a friend's VECO Tom Tom powered by a weak McCoy .29 gold head. The plane flew fine, the flyer did not. Since we were in knee-high grass I only broke the wooden prop.
Never flew the tomahawk.
George
George Bain
AMA 23454
Offline Bootlegger
Re: Veco Tomahawk
« Reply #9 on: June 05, 2013, 01:13:50 PM »
  Guy's I sure do thank y'all for all the responses, and those that built and flew the Tomahawk what engine did you find worked best on one?
  I have an O S 20 and a couple OS 25's ,was thinking about the 25's, but after reading I am re-thinking engine size, what about an O S 15 on the model, and I am thinking about "scratch" building one also. If I had a kit I think that I'd hold on to it instead.
  Again I sure do appreciate all the responses... y1
Gil Causey
AMA# 6964
Re: Veco Tomahawk
« Reply #10 on: June 06, 2013, 07:45:41 AM »
I thought I answered that.   Didn't have the OS back then.
Re: Veco Tomahawk
« Reply #11 on: June 06, 2013, 10:54:11 AM »
Brother Gil,
Both of the Tomahawks I mentioned are flown with an OS .20FP (BBTU).  A great combination!
BIG Bear
RNMM/AMM
