  • August 04, 2025, 02:37:15 AM
Author Topic: My magnum (with pics)  (Read 2176 times)
« on: July 18, 2006, 02:58:07 PM »
Seeing as all the other Magnums are being posted etc....here is the one I have nearly completed....just need the fuel tank, wheels and muffler.
As it sits it weighs 59.3oz........with the LA46 in front.  I am hoping the 46 will pull it round OK or I may have to go to a super tigre 51.
Offline Leester
Re: My magnum (with pics)
« Reply #1 on: July 18, 2006, 03:01:19 PM »
Looks good Wynn, what did you do to keep it under 60oz?
Leester
ama 830538
« Reply #2 on: July 18, 2006, 03:04:59 PM »
Wynn,
Very clean looking. I like the colors. Should fly fine with the 46.
Offline Tom Dugan
« Reply #3 on: July 18, 2006, 04:23:51 PM »
Wynn,
Is this a Magnum built from a Sig kit?  Didd you build it as the plans call...what did you do to cut weight?
Thomas
Offline Greg L Bahrman
« Reply #4 on: July 18, 2006, 05:54:40 PM »
Hey Wynn,
It looks really good. I like it!! Good to see you did better with the weight than I did. You'll have a good time with it. All monocoat ??
Greg Bahrman, AMA 312522
Simi Valley, Ca.
« Reply #5 on: July 18, 2006, 06:07:12 PM »
Wing is built up, not foam.....that saved a ton of weight.....
built pretty much form plan, obviously canopy is a little  different
saved weight wherever possible...lots of sanding....that helps.....good wood is the best start tho.......
wings are done in SIG aerokote......fuse is painted with rattle can lacquers......fuel proofed with a clear coat.
cant wait to fly it....should be fun.......
Offline Mike Clark
  • Lets get together and burn some fuel!
  • ACE
« Reply #6 on: July 18, 2006, 08:42:06 PM »
Hi Guys,
Yep as I thought, Built up wing. Nice Job
With all the Magnums showing lately maybe Sig will ARF the Magnum, you think?
Greg just now starting to cover my Mag Plus. Hopefully pictures next week.
Mike Clark
Mike Clark
« Reply #7 on: July 18, 2006, 09:46:49 PM »
Mike,
you have a built up wing in the Mag plus?
Offline Mike Clark
  • ACE
« Reply #8 on: July 22, 2006, 08:10:30 AM »
Hi Guys,
Yes Sir it is! The only way to travel.
Mike Clark
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #9 on: July 22, 2006, 06:54:33 PM »
Although the picture was vaporized from the forum, I did see it proir to the problems.  It does look very nice Wynn.   y1  Let us know how it flys.
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
