  • July 02, 2025, 06:13:17 AM
Author Topic: Tutor 11 w/ST51 Best recomended prop  (Read 878 times)
Offline David Fretz
« on: April 02, 2018, 11:26:01 AM »
So I don't waste a lot of time trying many different props, what do I start with. There are many of these planes with this engine so what worked best for you.
Re: Tutor 11 w/ST51 Best recomended prop
« Reply #1 on: April 02, 2018, 11:48:18 AM »
The  Cyclone  12.5 x 5.5  works  well ,  so does  Props like  Zinger Z 12 x 4 and  12 x 5
Offline David Fretz
« Reply #2 on: April 02, 2018, 02:59:30 PM »
Thank you, Randy S
Offline Larry Fruits
« Reply #3 on: April 02, 2018, 07:58:47 PM »
David,
 I have been using a Zinger 12 x 5 cut down to 11-1/2 inch diameter, for several years and it has worked very well. Recently I have been using a Mejzlik 12 x 4.3 cut down to 11 inch diameter (3) blade. I works great. I tried many props and like the above two the best.
 Good luck;
   Larry
