General control line discussion => Open Forum => Topic started by: David Fretz on April 02, 2018, 11:26:01 AM
So I don't waste a lot of time trying many different props, what do I start with. There are many of these planes with this engine so what worked best for you.
The Cyclone 12.5 x 5.5 works well , so does Props like Zinger Z 12 x 4 and 12 x 5
Thank you, Randy S
David,
I have been using a Zinger 12 x 5 cut down to 11-1/2 inch diameter, for several years and it has worked very well. Recently I have been using a Mejzlik 12 x 4.3 cut down to 11 inch diameter (3) blade. I works great. I tried many props and like the above two the best.
Good luck;
Larry
