Hi Dennis,
Yes I did, and it looked quite impressive in the air but, there was a slight problem. Not sure if it was due to the moisture in the air, but the speed controller was playing up. It would rev up to full speed then after a few seconds it would pulse, slower, for a fraction of a second then resume full speed again, and it would continue to do this over and over. Slowing down the speed would cure the problem but then the model was so slow it was un-flyable. I did some testing with an RC transmitter/receiver, changed the battery, disconnected the lights and the problem was still there so I deduced it must be the speed controller. I will try another ESC that I have here. Any thoughts?
One thing I noticed, due to the brightness of the lights you could see how high above the ground the model was really clearly, and I really felt comfortable about doing aerobatics, but only for my concerns about the model slowing too much. I did a loop and nearly lost it so that was it.
The Vets Gathering is one of our most popular events here, with better attendance than most contests. The mix of RC, CL and FF makes it a really fun weekend.
Cheers
