  • June 26, 2025, 11:47:42 AM
Author Topic: blank  (Read 1947 times)
Online Motorman
blank
« on: July 05, 2013, 09:32:29 PM »
blank
« Last Edit: September 08, 2021, 10:13:54 PM by Motorman »
Re: Wrinkle Free Cling Wrap
« Reply #1 on: July 06, 2013, 08:22:43 AM »
Not that I know of. ??? ???
« Reply #2 on: July 06, 2013, 09:53:23 AM »
  Use wax paper instead. Never had much luck with plastic wrap.
    Good Luck and Have Fun,
Offline Ward Van Duzer
« Reply #3 on: July 06, 2013, 10:23:20 AM »
I think you might find that since Microwaves, waxed paper has been made porous, therefore it no longer seems to shed glue.
(If thats what you're after...)
W.
« Reply #4 on: July 06, 2013, 02:27:56 PM »
I would try 4 hands and the Windex/squeege method.  y1 Steve
« Reply #5 on: July 06, 2013, 04:02:13 PM »
I often use parchment paper in place of waxed paper.  Has worked just fine so far.  As to the other wrap, I'll watch this thread closely to see if we get a good answer, cause I wanna know, too!
Offline John Cralley
« Reply #6 on: July 06, 2013, 04:07:06 PM »
What Steve says!!  y1
Only I would try to find some heavy duty freezer wrap or the stuff they use for shipping wrap.
John Cralley
AMA 52183
Central Illinois
« Reply #7 on: July 06, 2013, 05:13:08 PM »
W.
I use Cut-Rite waxed paper and have not had a problem with anything sticking very severly.  Occasionally if left for a long time the very low viscosity CA can stick a little but can be pulld off if done carefully and "peeled" rather than lifted.
Epoxy and slo-set CA is no problem.
I've never been able to use the plastic wrap stuff.  Guess I'm just too clumsy because I usually can't even get it cut off without turning it into a BALL!  LL~
« Reply #8 on: July 06, 2013, 05:21:40 PM »
I just answered the question as asked. I would not try to build over plans with any of the plastic wraps...CA glues it to your structure very firmly. I would trust Tyrone and use the parchment paper...he builds a LOT!  y1 Steve
Offline Noel Corney
« Reply #9 on: July 06, 2013, 06:08:44 PM »
I have found BAKING paper is the best for this and many other jobs in the shop, It's not porous and does the same job as wax only better, I have had no luck with cling film. Noel.
« Reply #10 on: July 06, 2013, 09:51:58 PM »
  Hi Noel;
    That is what we call parchment paper in the US. It's used for lining pans for baking. It's also a bit thicker and heavier than wax paper, and is more durable in the oven.
    Now I'm hungry for chocolate chip cookies! y1 y1
