Congratz Bill !!!
The clover is not too hard. Now the hour glass gives me fits. Hitting that second corner is a nut buster if you lose a lot of speed. The lines go slack. Or miss judge the wind. Then if you turn the third corner and head down it's full speed!
If I had a hunk of coal in my shorts I could have made diamonds a few times.
One thing I see time and time again, that tends to make this a lot harder for beginners and intermediate fliers, is that they don't let the airplane fly up *nearly* far enough before the second corner. They will absolutely *jam* the entry corner, killing all the speed, then let the airplane fly up to maybe 60 degrees, then do a slight "kink" to make the "second corner" and wind up flying almost vertically for the "top" of the maneuver. To get it back where it belongs, on the way down, they have to do a 180 degree u-turn, which usually stalls the airplane and then it's the old "s-turn" descent and near-death experience trying to get the last corner in.
If anyone is having problems, make sure that you don't hammer the entry. If you have to, whip the airplane for a half-lap before the entry and then swoop into it. Make sure that you fly all the way to the plane of your shoulders, or beyond, then make sure you do a full 120 degree corner, not just a quick stab at it. That will make the third corner a lot easier, and you will be able to get the descending leg established much higher, and make that last corner a lot less of a problem.
