  • June 19, 2025, 08:21:41 PM
Author Topic: T Rex PDF  (Read 5750 times)
Offline Bradley Walker
    • The Urban Rifleman
T Rex PDF
« on: May 09, 2014, 12:53:01 PM »
For free.  There you go...
B
-George Bernard Shaw
steven yampolsky
Re: T Rex PDF
« Reply #1 on: May 09, 2014, 12:55:23 PM »
B
Any chance for a DWG version? I would love to study how you draw such great plans. Mine are utter crud compared to yours.
Re: T Rex PDF
« Reply #2 on: May 09, 2014, 01:09:58 PM »
There you go.
steven yampolsky
Re: T Rex PDF
« Reply #3 on: May 09, 2014, 01:32:13 PM »
This is awesome! I'm already pouring over it!
Two questions:
1) How do you go about assigning color to different sections? What's your approach?
2) I have been trying to group together shapes that belong together like an elevator on side view. On your plans most shapes are ungrouped. Is there a value in grouping or am I wasting time?
Re: T Rex PDF
« Reply #4 on: May 09, 2014, 06:39:22 PM »
Two questions:
I know this question was directed to Bradley but, I will just chime in,(that is what we do on this forum!). I personally don't bother with grouping. I just focus on layers. That is the key-focus on layers for control of the drawing.
Offline Doug Moon
Re: T Rex PDF
« Reply #5 on: May 12, 2014, 07:56:28 AM »
Yes, layers.  It easier and faster.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Re: T Rex PDF
« Reply #6 on: May 12, 2014, 08:28:54 AM »
#2 graphite works pretty good for me.
Re: T Rex PDF
« Reply #7 on: May 12, 2014, 11:39:04 AM »
If its so popular, how come its only #2???
Re: T Rex PDF
« Reply #8 on: May 12, 2014, 12:21:34 PM »
I dunno Denny.  Maybe Crayola was #1.  I takes 4 years of drafting technology then some smart$$X comes up with autocad.
Re: T Rex PDF
« Reply #9 on: May 12, 2014, 01:13:44 PM »
Amen brother!  Old habits are hard to break, like holding a french curve on the PC to draw airfoils..!
Re: T Rex PDF
« Reply #10 on: May 12, 2014, 02:27:05 PM »
Two questions:
Truthfully, it's been so long since I did 2D I don't think about it much.  I have been working in 3D modeling for more than 6 years.
Colors are for YOU.
When you print, the really kick butt looking drawings have the correct line weights when they plot.  That is the most important thing.  Colors should be assigned to line weights.
Offline Lauri Malila
Re: T Rex PDF
« Reply #11 on: May 12, 2014, 03:11:05 PM »
L
Offline t michael jennings
  • AMA 83322
Re: T Rex PDF
« Reply #12 on: May 12, 2014, 06:15:14 PM »
Mr. Walker,
Does the T-Rex have an engine offset?
If it does have an offset, is the Firewall offset or is the RC type engine mount drilled for the offset?
Thanks for your answer.
T Michael Jennings      :P
Knoxville, TN.
Re: T Rex PDF
« Reply #13 on: May 16, 2014, 05:29:26 AM »
Brad:
I forgot to THANK YOU for posting the DWG file.   H^^
Dennis Leonhardi
Re: T Rex PDF
« Reply #14 on: May 16, 2014, 10:09:21 AM »
Aren't airfoils supposed to have French curves!??  I'll be darned if I'll draw them with Norwegian curves ...
Dennis
Re: T Rex PDF
« Reply #15 on: May 16, 2014, 08:04:31 PM »
I don't dare hold French curves, my wife would kill me! LL~ LL~ LL~ LL~ LL~
Re: T Rex PDF
« Reply #16 on: May 20, 2014, 10:30:05 AM »
Mr. Walker,
Knoxville, TN.
If you want offset I would use a 1/64 ply shim or aluminum shim under the mount.
Just a tweek...  The TRex has great line tension without much help.  Due to the fact that is has a lot of forward side area.
Re: T Rex PDF
« Reply #17 on: May 20, 2014, 10:31:47 AM »
I am going to upload the TRex 50 and TRex Jr here in a bit.
The TRex 50 is the real killer.  I was saving it for myself....  but what the heck.
Re: T Rex PDF
« Reply #18 on: May 20, 2014, 11:12:54 AM »
T Rex 50 PDF.
Re: T Rex PDF
« Reply #19 on: May 20, 2014, 11:14:28 AM »
T Rex 50 DWG
Re: T Rex PDF
« Reply #20 on: May 20, 2014, 11:15:04 AM »
T Rex 40 PDF
Re: T Rex PDF
« Reply #21 on: May 20, 2014, 11:15:47 AM »
T Rex 40 DWG
Re: T Rex PDF
« Reply #22 on: May 20, 2014, 02:18:40 PM »
  The aerodynamic design on the original looks pretty darn good, and the construction shown would not have the problem the ARFs have/had. Very useful to post .DXFs, thanks.
Re: T Rex PDF
« Reply #23 on: May 20, 2014, 03:44:50 PM »
I will put the Trex up against anything out there really...
But most everything out there is almost exactly the same.
So, that's not really being that controversial.
Re: T Rex PDF
« Reply #24 on: May 21, 2014, 12:20:18 PM »
Walter Umland says he is going to be making short kits.
Re: T Rex PDF
« Reply #25 on: May 21, 2014, 03:39:51 PM »
That's the way to do it!!!
Re: T Rex PDF
« Reply #26 on: May 21, 2014, 11:53:40 PM »
  "The Box" exists for a reason.
Offline Bootlegger
Re: T Rex PDF
« Reply #27 on: May 23, 2014, 04:17:11 AM »
 Don't know if I did something wrong, but I couldn't get the T Rex 40 dwg to down load. What coud be wrong?
  Any one else having this problem?   Thanks, Bootlegger
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline 55chevr
Re: T Rex PDF
« Reply #28 on: May 23, 2014, 04:00:01 PM »
yeah ... would not work for me either
Joe Daly
Offline Doug Moon
Re: T Rex PDF
« Reply #29 on: May 23, 2014, 04:08:42 PM »
I just tried it and it downloaded here no issues.
Doug Moon
AMA 496454
Re: T Rex PDF
« Reply #30 on: May 23, 2014, 04:20:35 PM »
   Worked fine when I tried it. It was so fast, I thought it had bombed out, but no.
Re: T Rex PDF
« Reply #31 on: May 23, 2014, 08:15:58 PM »
I can't get it to scale correctly but I haven't tried again. Brad, what is the "paper" size you use, maybe I can trick my plotter.
Re: T Rex PDF
« Reply #32 on: May 29, 2014, 09:59:20 AM »
36 x 60.
Offline Bootlegger
Re: T Rex PDF
« Reply #33 on: May 29, 2014, 02:42:54 PM »
 Brad, I just sent ya' a P/M.. Thanks, Gil
Gil Causey
AMA# 6964
Re: T Rex PDF
« Reply #34 on: May 29, 2014, 03:06:05 PM »
Nope the link works just fine.
