General control line discussion => Open Forum => Topic started by: Bradley Walker on May 09, 2014, 12:53:01 PM
For free. There you go...
B
B
Any chance for a DWG version? I would love to study how you draw such great plans. Mine are utter crud compared to yours.
There you go.
This is awesome! I'm already pouring over it!
Two questions:
1) How do you go about assigning color to different sections? What's your approach?
2) I have been trying to group together shapes that belong together like an elevator on side view. On your plans most shapes are ungrouped. Is there a value in grouping or am I wasting time?
Two questions:
I know this question was directed to Bradley but, I will just chime in,(that is what we do on this forum!). I personally don't bother with grouping. I just focus on layers. That is the key-focus on layers for control of the drawing.
Yes, layers. It easier and faster.
#2 graphite works pretty good for me.
If its so popular, how come its only #2???
I dunno Denny. Maybe Crayola was #1. I takes 4 years of drafting technology then some smart$$X comes up with autocad.
Amen brother! Old habits are hard to break, like holding a french curve on the PC to draw airfoils..!
Two questions:
Truthfully, it's been so long since I did 2D I don't think about it much. I have been working in 3D modeling for more than 6 years.
Colors are for YOU.
When you print, the really kick butt looking drawings have the correct line weights when they plot. That is the most important thing. Colors should be assigned to line weights.
L
Mr. Walker,
Does the T-Rex have an engine offset?
If it does have an offset, is the Firewall offset or is the RC type engine mount drilled for the offset?
Thanks for your answer.
T Michael Jennings :P
Knoxville, TN.
Brad:
I forgot to THANK YOU for posting the DWG file. H^^
Aren't airfoils supposed to have French curves!?? I'll be darned if I'll draw them with Norwegian curves ...
Dennis
I don't dare hold French curves, my wife would kill me! LL~ LL~ LL~ LL~ LL~
Mr. Walker,
Knoxville, TN.
If you want offset I would use a 1/64 ply shim or aluminum shim under the mount.
Just a tweek... The TRex has great line tension without much help. Due to the fact that is has a lot of forward side area.
I am going to upload the TRex 50 and TRex Jr here in a bit.
The TRex 50 is the real killer. I was saving it for myself.... but what the heck.
T Rex 50 PDF.
T Rex 50 DWG
T Rex 40 PDF
T Rex 40 DWG
The aerodynamic design on the original looks pretty darn good, and the construction shown would not have the problem the ARFs have/had. Very useful to post .DXFs, thanks.
I will put the Trex up against anything out there really...
But most everything out there is almost exactly the same.
So, that's not really being that controversial.
Walter Umland says he is going to be making short kits.
That's the way to do it!!!
"The Box" exists for a reason.
Don't know if I did something wrong, but I couldn't get the T Rex 40 dwg to down load. What coud be wrong?
Any one else having this problem? Thanks, Bootlegger
yeah ... would not work for me either
I just tried it and it downloaded here no issues.
Worked fine when I tried it. It was so fast, I thought it had bombed out, but no.
I can't get it to scale correctly but I haven't tried again. Brad, what is the "paper" size you use, maybe I can trick my plotter.
36 x 60.
Brad, I just sent ya' a P/M.. Thanks, Gil
Nope the link works just fine.
