I am going to be trying some fishing lines and don't have adj lead outs, what other method can you suggest if the fishing lines aren't the same drag as the steel ones, in tension/control,to do the needed adjustments, and how to adj the tip weight when there isn't a tip weight box? Have I made myself clear? Thanks
