  • July 18, 2025, 10:10:22 AM
Author Topic: Morris Printed Electric Motor Mounts  (Read 1210 times)
« on: May 31, 2023, 11:45:26 PM »
If any of you are using the Morris/Okie printed motor mounts, Please check them periodically.  I just had one that literally got bent out of shape by vibration.  I suspect that the motor got hot enough to soften the mount then the vibration stretched the holes.  Luckily I caught it.  These little motors put out a tremendous amount of torque and "they will bite you" if allowed to become loose.   I fixed it by adding a plywood cap.  If I use one of these again on a full body it will have reinforcement.
Offline Perry Rose
Re: Morris Printed Electric Motor Mounts
« Reply #1 on: June 01, 2023, 05:24:52 AM »
Get one that is cursive not printed.
« Reply #2 on: June 01, 2023, 06:05:08 AM »
LL~ I understand the Chinese are making them using calligraphy but they are not reinforced and have a 24mm hole pattern.
Online Paul Taylor
« Reply #3 on: June 05, 2023, 05:50:49 PM »
I reversed engineered (well had my son the CAD guy) the Okie Air mount. I did away with the entire center section and put in slots for the aluminum mount that comes with the motor. I think this allows for better cooling and the aluminum will dissipate the heat better and will not distort.
« Reply #4 on: June 05, 2023, 06:24:51 PM »
I am having a hard time picturing that but I think it is a good idea.  Do you have a picture?
Online Paul Taylor
« Reply #5 on: June 06, 2023, 03:15:52 PM »
Sure
Let’s see if I can attach a few.
« Reply #6 on: June 06, 2023, 03:35:53 PM »
Sure
I love it.  Is that the 28xx or 35xx mounting plate?
Online Paul Taylor
« Reply #7 on: June 06, 2023, 05:31:50 PM »
That’s a 28x. But I scale it in the slicer program to fit what ever spinner.
