Working on finishing up my Rescue S1 electric Ringmaster and need to apply tape over the hinge line. When this was built the builder used medium barrel hinges (flat type that goes into a slot). They were not recessed into a hinge pocket so the gap is about 1/16". They are in very good but I need to tape the hinge line. One option is to tape between the hinges with several pieces of tape, this is a pain. The easiest is to use one piece of tape down the whole thing, I have seen others say its just fine and the hinge will not bind.
Question, if you do the one piece approach should you put something like a small drop of chain lube on the hinge area to keep the tape from sticking to the barrel?
Many do this when they install the hinge to keep the adhesive from gluing the hinge together and perhaps that's why they don't have binding when taped over.
Best, DennisT
