  • June 30, 2025, 09:26:17 PM
Author Topic: I hit the COX mother load!!!  (Read 6286 times)
« on: November 07, 2008, 08:57:30 PM »
Seems a local hobby shop here in New Zealand has been unable to sell COX components for the last few years I asked to see what they had and the bought a a shopping cart full to overflowing with original cox parts, most in sealed packages - including a whole raft of plastic COX airplane parts - all new and unused.
So I made them an offer - and lets just say if you have an item you may need - but can't find. please let me know - as I sure dont need it all.
Offline Bill Adair
  • AMA 182626
Re: I hit the COX mother load!!!
« Reply #1 on: November 07, 2008, 09:25:32 PM »
Wynn,
Wow, I don't collect plastic airplanes, but the plastic parts and complete airplanes command pretty good prices on Ebay.
Did you get any engines or engine parts?
« Reply #2 on: November 08, 2008, 03:46:31 AM »
yes. plenty of engine parts. heads cylinders/pistons needles, carbs, bodies, reed valves, mufflers etc.  what are you looking for?
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #3 on: November 08, 2008, 06:30:47 AM »
Hey Wynn, how about .020 or (especially) .010 glow heads?
--Ray
AMA902472
Offline jamtx
« Reply #4 on: November 08, 2008, 11:39:14 AM »
Wynn, got any piston/cylinders for a 049 T.D.?
James
James Karnes
Abilene,TX.
Offline kenneth cook
« Reply #5 on: November 08, 2008, 01:42:42 PM »
  Wynn, I'd be very interested in tank backs if you have them. I'm looking for the die cast backplate with no filler pipes used on the golden bee, blackwidow. In the event you have the plastic ones with no fillers that would suffice as well.  Ken
Offline John KruziK
« Reply #6 on: November 08, 2008, 01:48:39 PM »
could use engine mount, tank,and canopy for me-109 thanks
AMA 874027
« Reply #7 on: November 08, 2008, 02:24:37 PM »
OK here is a list so far.......
.010 Needle Valve & Spring
.049 Glow Head
049 Product Engine
Airwolf Fin Stab Rotor Set
Airwolf Hub Rotor/Shaft Assy
Battery Pack Belt Clip 9561
Bearcat Canopy 9561
Bearcat Cowl 9561
Bearcat Elevator 9561
Bearcat L&R Landing Gear 9561
Bearcat Spinner 9561
Bearcat Stabilizer 9561
Bearcat Sticker Sheet 9561
Bearcat Wing 9561
Bell Crank AT6 Texan 9861
Bellcrank Corsair 9000
Bellcrank Retainer Texan 9861
Bellcrank Wire AT6-Texan 9861
C/Case Shaft/DR PL Asy
Canopy AT6 Texan 9861
Carburettor Assy R/C 211
Conductor Lines & Reel
Corsair 9000 Wing
Corsair Spinner
Cowl Left & Right 90490/1
Cowl Left & Right Lectra 90468
Cox 020 Pee Wee Starter Spring
Cox 049 Needle valve & Sp
Cox 049/051 C170 Needle Valve&Spring
Cox Carb.Body
Cox EZ Flyer C/Case-Shaft-Plat
Cox Needle Valve & Spring
Cox Needle Valve/Venturi-210
Cox Texaco Tank Front/Back Assembly
Cox Wrench 350-150-170
D/Fly Throttle & Muffler
Dragonfly Cylinder-Piston-Rod
Ejector Components 4800
Elevator Super Sport II
Fin Rudder Lectra 90467/8
Firewall R/C Comnder 90490
Foam Repair Kit
Fuel Filter Cap w/Hose
Fuel Tan-4500/4800
Fuselage Lower-ME109 5400
Fuselage R/C Comnder 90490
Fuselage R/C Lectra 90467/8
Fuselage Top Super Sport II
Fuselage Upper AT6 Texan 9861
Fuselage-Lower Front
Fuselage-Stabilizer
Gas Car 049 Glow Head
Landing Gear Assy
Left Fuselage Half Bearcat
Lower Nose AT Texan 9861
ME109 Bellcrank-Cox
Medallion 049 Part Set
Medallion Needle Valve/Spring
Motor Deco Cover Lectra 90467/8
Motor Mount R/C Lectra 90467/8
Muffler 09 Tee Dee
Mustang Wing
Pee Wee 020 C/Case-Shaft
Pee Wee 020 Needle Valve
Pee Wee Glow Head
Prop Drive Hub 9561
Prop Hub 5700
Prop Hub 9561
Prop Stub 5700
Queen Bee Cylinder/Piston
Queen Bee Glow Head/Gasket
Queen Bee Reed Ret&Housing
Right Fuselage Half Bearcat
Rotor Hub Bearing Centre Shaft
RS-380 Motor 9561
Rudder Thunderbolt 4040
Sky Ranger Canopy Assy
Sky Ranger Fuselage Left
Sky Ranger Fuselage Right
Sky Ranger Landing Skid
Sky Ranger Plate, Motor Mount
Sky Ranger Rotor Hub-Shaft Ass
Snap Starter kit
Stabiliser AT6 Texan
Starter Cam LH Hex Dr PLT
Sticke Sheet Lectra 90468
Sticker Set AT6-Texan 9861
TD 020 C/Case, Shaft & Carb
Teedee 049 Tank & Mount
Thunderbolt Canopy
Thunderbolt Wing 4040
Vert Fin Left Hornet
Vert Fin Right Hornet
Wheel AT6 Texan
Wheel Corsair
Wing PT19 Cox
PT-19 nose cowls
also - glow heads  - 020, 049.
many more items - still going through it all
« Reply #8 on: November 08, 2008, 05:44:53 PM »
Do you have any Cox TD parts?
I could use a P&C for a TD .051, and a TD .15 MK-II Special.
Offline Stan Bidowski
    • Winnipeg Perfect Circle Flying Club
« Reply #9 on: November 08, 2008, 08:03:25 PM »
Hi Wynn,
   Didn't you get my email to you  ??? ?  I'm interested in the Cox Texaco tank and backplate if it is
metal ( as in my email I sent, also Black Widow or Golden Bee tanks ).  Also the Tee Dee black plastic
or red plastic carb body that is on the front of the crankcase that the venturi screws into,
some Killer Bee crankshaft/crankcases, and 5x4 or 5x3 black props.
Thanks  H^^
 Stan Bidowski
MAAC 17167
    • Minnesotamodeler
« Reply #10 on: November 09, 2008, 06:35:07 AM »
Remember me if you come across any .010 glow heads.
--Ray
AMA902472
Offline Larrys4227
« Reply #11 on: November 09, 2008, 04:31:37 PM »
Wynn - If you come across any Thimble Drome pickup tubes with/without the pickup spring inside, let me know.
I could use 2 standard compression 049 glowheads.
larrys4227(at)yahoo(dot)com
FlySafe!  Larry (Larrys4227)
