  • June 15, 2025, 09:51:09 AM
Author Topic: Outbox/Sent Messages ?????  (Read 1378 times)
Offline Roger Vizioli
  • CLiner
« on: August 29, 2021, 10:43:18 PM »
Cant find my outbox.
Went through Search/Outbox. Tried all suggestions, still no Outbox.
I do check the box to save Outgoing messages.
Suggestions/Help?
Thx,
Roger Vizioli
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Craig Beswick
Re: Outbox/Sent Messages ?????
« Reply #1 on: August 29, 2021, 11:19:54 PM »
No drop down box when you click on Messages?
AUS 87123
"The Ninja"
« Reply #2 on: August 29, 2021, 11:21:42 PM »
Click "My Messages" from the menu bar, choose "Read your messages". Over on the left, you will find this:
  • CLiner
« Reply #3 on: August 30, 2021, 12:58:20 PM »
Craig and Brett-
Craig - no drop down box, just a list of messages received.
Brett -Thanks. tried that. What I get when selecting "Read your messages"   is an ID for Inbox and a list of all my incoming messages.   ????? Nothing else.
An after thought - I had my hard drive changed and all info on the old drive was "supposedly" transferred to the new drive.
Is it possible they missed this Outbox command? Cant remember if I looked for "Outbox" after I had hard drive changed, until the other night.  ????? I have the old hard drive.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #4 on: August 30, 2021, 01:14:48 PM »
  When you are typing a new message, look at the bottom left corner for the box "save a copy in my outbox." Click that and it should save all of them you send until you clear that box again. I had the same issue once.
  • CLiner
« Reply #5 on: August 31, 2021, 01:58:04 PM »
Dan,
Thx.
I always did that AND since this problem started I tried to send a few new messages , double checking that I checked the box before sending.
I still dont have an outbox.    ??? ???
Take care, Stay Safe!
Roger
ps I have lots of time to trouble shoot,going through treatment for pinched (we believe) Sciatica so I cant fly but doing alot of sitting and prepping for my next "must build!"      y1
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #6 on: August 31, 2021, 05:32:17 PM »
Sorta had that problem once, a year or two ago. Wave your cursor over "Messages" on the left. Dropdown menu has three options, "new message", "Inbox" and "Sent Items". The last is the one you click on. This is on MS Edge.
I can't imagine any reason why your hard drive swap would have any effect on this, but perhaps the OS or browser, so would ask what OS your computer runs on and what browser you're using. However, I'm not a computer geek. If that's not it, then either you're simply not seeing it, or you just don't have any saved messages, IMO.  H^^ Steve
  • CLiner
« Reply #7 on: September 01, 2021, 01:53:31 AM »
Steve,
THANKYOU for the suggestion!
When Messages box came up, the drop down only included New Messages and Inbox.
I tried your suggestion and  waved the cursor over "Messages " a few times CLICKING IT and Sent Items mysteriously appeared.
All my "Sent items were listed.
It is real late but I  will power down and try it again.
Will send results before I turn in.
Roger
Update: Powered up, drop down showed all three selections. Again,  THANKYOU!    H^^
Good Night   uhhh   Good Morning!
« Last Edit: September 01, 2021, 02:10:45 AM by Roger Vizioli »
Roger Vizioli
AMA L-2408
Florida/Space Coast
