  • June 25, 2025, 07:13:44 AM
Author Topic: Brett Buck Bellcrank  (Read 4749 times)
John Leidle
« on: December 29, 2010, 01:34:48 AM »
     Would someone post a picture of one for me large enough for me to examine? I  found one on micro film in CLC's site,
  john
Re: Brett Buck Bellcrank
« Reply #1 on: December 29, 2010, 04:06:33 AM »
  john
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=332148&mesg_id=332148
Offline peabody
« Reply #2 on: December 29, 2010, 04:34:58 AM »
I believe that Tom Morris sells/sold a nice looking copy of Brett's
Offline John Lindberg
« Reply #3 on: December 29, 2010, 08:50:36 AM »
I bought one from Tom a few years ago, real nice unit, now I have to build something for it. ~>
John Leidle
« Reply #4 on: December 29, 2010, 09:29:50 AM »
   I truely like the little teardrop items... I want to call them shivs or clevis's but I dont think that is the proper term for it.
« Reply #5 on: December 29, 2010, 09:40:59 AM »
John,
Yea, I've been making those out of PC board and putting in a bronze bearing. Works pretty well, too.
Offline Ron Merrill
« Reply #6 on: December 29, 2010, 10:33:23 AM »
CLC sells this bellcrank. y1 Ron.
John Leidle
« Reply #7 on: December 29, 2010, 10:53:44 AM »
  I am impressed with the bellcrank.
« Reply #8 on: December 29, 2010, 11:38:44 AM »
I think 'thimble' is the best choice, although 'bushing' may do.
They look like hard gizmos to machine -- if someone had the wherewithal to mold them out of nylon or something it'd make production faster.
Offline Mike Haverly
« Reply #9 on: December 29, 2010, 12:29:40 PM »
     I bought one from CLC and was a little disappointed.  They are not like the original by Brett but made for the "up" line in back.  If that's your preference, then OK.  The other things different for me was that the leadouts were .036" dia and crimped not wrapped.  I use .028" dia.  The hole in the bushing was off center, and the bushing in my opinion was too short.  This is not to say they are totally no good, just not what I expected.
     I made one (actually more than one) the way I wanted, with the "up" line in front.  I looks pretty much like Brett's.  It is not difficult, Brett posted some specific instructions somewhere, SSW I think.  The thimbles are easy to make.  They are made of .125 Phenolic plate (PC board) and shouldn't take more than ten minutes for both.  Cut them out on a scroll saw, sand smooth, and form a groove with a Dremel tool.  The Aluminum plate is .025" and available at most hardware stores and hobby shops.  This also can be cut with a scroll saw.  I made the bushing from .250 dia. brass.
Mike Haverly
« Reply #10 on: December 29, 2010, 03:17:20 PM »
    I cut them out with a jigsaw, then cut the groove with a Zona saw and then widen it out with needle files. That's not the hard part. The hard part is the bushing. Trivial with a lathe, not so trivial with hand tools.
« Reply #11 on: December 29, 2010, 03:21:37 PM »
I cut them out with a scroll saw and used a ball end keycutter mill to cut the groove using a jig. Worked pretty well. I bought the bushing from Lowe's. It's a .250" diameter bronze unit with a lip and an inset. I used a piece of .250" bronze tubing for the post. Works extremely well.
I should also say that while mine is similar to Brett's unit, the bellcrank itself is molded out of carbon fiber rather than the aluminum sandwich Brett uses.
« Reply #12 on: December 29, 2010, 07:56:33 PM »
sometimes multiple peices of CF  HB~> LL~
« Reply #13 on: December 29, 2010, 10:53:41 PM »
Mark,
Only when I cut them in half.
