  • June 18, 2025, 11:35:07 AM
Author Topic: Generator for the NW Regionals  (Read 1106 times)
Online Howard Rush
« on: May 26, 2011, 01:54:53 PM »
Does somebody have a 115V generator that puts out at least 1000 watts that we can use at the stunt circle?  It would greatly reduce the workload for Scott and his crew.
Howard
Re: Generator for the NW Regionals
« Reply #1 on: May 26, 2011, 02:17:21 PM »
I thought cattle prods were battery powered.
Online Howard Rush
« Reply #2 on: May 26, 2011, 02:22:12 PM »
We have special cattle prods that shoot ball lightning at slow-moving contestants' ... well, that's why they call it ball lightning.
« Reply #3 on: May 26, 2011, 04:39:17 PM »
You would be welcome to use my 4K but I've been running it a lot lately to allow my sump pump to run every 15 minutes!!  Why does our power always go out at night instead of when I don't want to sleep!? HB~> HB~> ''
« Reply #4 on: May 26, 2011, 06:18:43 PM »
I'm in trouble then -- all my engine runs seem to either end in the middle of a loop, or run on well past the end of the pattern.
Offline Derek Moran
« Reply #5 on: May 28, 2011, 08:43:06 AM »
Dan has a Honda generator.  Actually, he has a Honda and an inverter.  The inverter has sufficient capacity to power a MonoKote iron which ought to be fine for your *new* printer.  The whole setup is not much bigger than a dedicated gas generator.  An added advantage is you don't have to push it to and from the ED's tent.
Derek
AMA 82617
