  • July 11, 2025, 02:17:47 AM
Author Topic: Midwest Warbird Plans  (Read 1965 times)
Mike Griffin
« on: September 27, 2010, 03:51:04 PM »
If anyone might happen to have a plan of an old Midwest Warbird kit, would you mind posting it if you can. I would like to see the dual pushrod setup on the plan.
Offline W.D. Roland
Re: Midwest Warbird Plans
« Reply #1 on: September 27, 2010, 04:16:12 PM »
Hi Mike
I may have a set of plans for Midwest P-40, I have P-40 that is from 1979 build that I still fly.
I can tell you that the pushrod for the Flaps is in the outer hole on perfect 3" bellcrank and the elevator rod is in the next hole in towards bushing.
With O.S. .35s it needed close to 3oz of tail weight so recently I rebuilt the nose shorter and hit it almost dead on the money with no tail weight.
The weight reduction help a lot! current weight is 42oz.  36-38 would make a great flier!
I do not remember how much it was shortened although remember that the rear engine mount bolts were past the hardwood bearers by some small amount.
The throws at the control surface I have no idea of total deg of movement as over the years have moved them all over the place.
Will dig in the big box for plans as soon as possible but do not think I kept them. HB~>
David
David Roland
51336
« Reply #2 on: September 27, 2010, 05:03:44 PM »
Heres the Skyraider
Offline jim gilmore
« Reply #3 on: September 27, 2010, 05:09:50 PM »
I'd like to see the other plans..me109,p39orp63..these would scale down to 1/2a real nice.
Offline RogerGreene
« Reply #4 on: September 27, 2010, 05:24:56 PM »
Mike,
Here is the Midwest P51 bellcrank showing the pushroods.
Roger
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
Mike Griffin
« Reply #5 on: September 27, 2010, 08:32:57 PM »
Thanks Guys.  This helps a lot..I appreciate everyone taking the time to do this.
MIke
