  • July 19, 2025, 05:28:33 PM
Author Topic: blank  (Read 1445 times)
blank
« on: August 01, 2018, 08:01:30 AM »
blank
« Last Edit: September 26, 2021, 11:11:36 PM by Motorman »
Offline Tom Luciano
Re: Middlesex Modelers Contest this Sun?
« Reply #1 on: August 01, 2018, 08:39:59 AM »
Walt,
  Pampa stunt all classes. Current location is North Branch park in Bridgewater nj. BUT!!!! we are now under a TFR from 8/3-14. Jim V. Is working on getting us a clearance or change in Venue.
THERE WILL BE A CONTEST!
Hope to see you out there
Tom
AMA 13001
Offline jfv
« Reply #2 on: August 01, 2018, 09:36:40 AM »
Trying to get a waiver from the FAA.  Should know one way or the other by tomorrow.  If we can't get the waiver it will be held at the GSCB field.  Four classes of PAMPA and one class of Old Time.
Jim Vigani
Offline Frank Imbriaco
« Reply #3 on: August 01, 2018, 09:55:02 AM »
Jim Vigani has experienced more grief than probably any CD the past two years. Imagine the FAA lumping control line flying with radio controlled models of every type.
Just unbelievable.
Flyers in Central and Northern NJ have it worse than anywhere else in the nation. In July, radio flying halted because of TFRs  for a total of eighteen days.
Now it's August- already a  TFR issued for Aug 2-13 at all radio fields within 50 miles.
Reason ?- the President just can't seem to get enough of his estate/golf course in Bedminster, NJ.
Now before guys start saying, "we'll who cares, it's R/C ",  we have R/C fields that allow control line. R/C fields are a perfect venue. Wide -open, clean air.
THE FAA seems to have gotten things pretty mixed up.
Wonder from whom.
Can we say AMA ?
************************* P.S. - JIM will pull it off ! The contest WILL go on !*************
Offline peabody
« Reply #4 on: August 01, 2018, 11:04:55 AM »
Frank
I seriously doubt that blame lies with the AMA..... they have been clear and have lobbied to keep control line flying out of the NOTAMs.
And a lot of FAA reps that I have talked with agree.....this issue is that lower level FAA and Secret Service types have only been told that model airplanes can't fly in restricted airspace. Like most law enforcement people that I have known, they tend to err on the side of caution. I doubt that there is a bulletin that explains the difference between RC and CL, even though the AMA has efforted to do so.
Have fun!
Offline Skip Chernoff
« Reply #5 on: August 01, 2018, 11:10:49 AM »
All...if you run into trouble....or your GSCB site is under water....you are more than welcome to use our Neshaminy site. I'll personally cut the grass for you......Cheers,Skip
Offline Mike Ferguson
« Reply #6 on: August 01, 2018, 11:21:31 AM »
Frank
Have fun!
Even if they know the difference, the North Branch field is primarily R/C. Easier for them to just shut it down completely rather than to make exceptions.
« Reply #7 on: August 01, 2018, 11:55:54 AM »
Frank
Have fun!
Hi Rich :
I have yet to see one scintilla of evidence in writing that supports your assertion. The AMA has known about this particular situation and has punted the matter back to the CD to iron it out with the FAA.
Cheers !
Frank
Offline George Waters
« Reply #8 on: August 01, 2018, 08:10:04 PM »
A couple of weeks ago I read two articles in the Asbury park news . AMA rep Eric Williams was making the case for the RC fliers but never mentioned controline once in either piece. Makes one wonder?    George
