  • July 13, 2025, 10:45:08 PM
Author Topic: Perma-Grit tools  (Read 2747 times)
Mike Griffin
Perma-Grit tools
« on: February 14, 2013, 03:32:02 PM »
Have any of you had trouble finding the Perma Grit Tools either on line or in the hobby shops.  Seems like it is getting hard to find anyone who carries the line.  I just ordered the hand sanding set but it is coming from Perma-Grit in England...
Re: Perma-Grit tools
« Reply #1 on: February 14, 2013, 03:36:21 PM »
I believe Micro-Mark is the only place to get them over here.  H^^
Mike Griffin
« Reply #2 on: February 14, 2013, 04:00:50 PM »
Thank you Steve.  I had a bad experience with them on a band saw a couple of years ago so I am glad I ordered where I did...
« Reply #3 on: February 14, 2013, 04:03:35 PM »
   You used to see them all over the place but I had to get mine from England more recently. Great tools.
Offline tom brightbill
« Reply #4 on: February 14, 2013, 04:52:26 PM »
Mike,  Can you please post the link that you used?  Thanks,  Tom
AMA 34849
Offline Alan Resinger
« Reply #5 on: February 14, 2013, 05:06:14 PM »
Mike,
You can get most of the line from Aircraft Spruce.
Alan Resinger
Mike Griffin
« Reply #6 on: February 14, 2013, 05:21:39 PM »
That is where I got mine from Brett.  Here is the link you asked for Tom.
http://www.permagrit.com/
Thanks for the Aircraft Spruce tip Alan...
These things just do not wear out.  I have a coarse flat bar I bought years ago and am still using it.. Takes a lot of balsa off in a hurry.
Mike Griffin
« Reply #7 on: February 14, 2013, 05:47:34 PM »
Thanks for the source Bob....
« Reply #8 on: February 14, 2013, 06:12:08 PM »
Permagrit tools-absolute must for serious building.
« Reply #9 on: February 14, 2013, 06:14:29 PM »
I bought a set at a trade show about 10 years ago. Still using the same ones.
« Reply #10 on: February 14, 2013, 07:47:33 PM »
  I'll have to check last years vendor list, but I think they usually have a both in the vendor buildings at Oshkosh each year. If I can lay my hands on the bookd when I get home tonight I'll check. If they display there, they must have some kind of distribution in this country.
Online bill bischoff
« Reply #11 on: February 14, 2013, 09:18:42 PM »
Central Hobbies sells them, along with lots of nifty Tettra and MK stuff.
Offline Mike Gretz
  • ACE
« Reply #12 on: February 15, 2013, 06:13:38 AM »
Perma-Grit sanding tools are great and yes, they are made in Great Britain..  http://www.permagrit.com/
There's another company, in Canada, called Dura-Grit.  I've used their products too and found them to be just as good as Perma-Grit.  http://www.duragrit.com/
steven yampolsky
« Reply #13 on: February 15, 2013, 06:34:52 AM »
Central Hobbies in Billings, Montana has them. They specialize in RC Pattern so they are OK in my book.
http://www.centralhobbies.com/Tools/perma-00.html
While there pickup some pushrod ends. best around!
Offline Willie Johnson
« Reply #14 on: February 15, 2013, 09:04:27 AM »
I got some from Wicks
Willie Johnson
AMA 774461
