  • July 17, 2025, 08:39:18 PM
Author Topic: Mini Mo Best gettin some color  (Read 1912 times)
Offline Leester
« on: September 04, 2010, 08:31:31 PM »
It's not as big as the "G" Mans plane but it's taken about as long. Hope to get some clear on it monday. I'm using Brodak dope and will clear with the Brodak Crystal clear.
Leester
ama 830538
Re: Mini Mo Best gettin some color
« Reply #1 on: September 04, 2010, 09:20:36 PM »
 Lookin' good so far! y1 Is that a green canopy?
Offline Leester
« Reply #2 on: September 04, 2010, 09:27:43 PM »
Yes, it was a poor attempt at using candy apple colors.
Leester
ama 830538
« Reply #3 on: September 05, 2010, 03:01:02 AM »
Looks pretty good, Lee!
What is the info on the *MINI* MO Best?
Mongo
Offline Leester
« Reply #4 on: September 05, 2010, 07:36:08 AM »
Bill, it's an approximate 25% reduced version. W.S. 44 1/2  length nose ring to tail is 29" don't know how to figure the sq's. I'll start with a FP 20 and can move up to the FP 25 if needed.
Leester
ama 830538
« Reply #5 on: September 05, 2010, 08:01:41 AM »
I like it.   H^^
Offline Leester
« Reply #6 on: September 05, 2010, 03:37:05 PM »
Todays work on it. Flaps, Elevators and wheel pants are painted with Dupli-Color and clear is MinWax Poly.
Leester
ama 830538
steven yampolsky
« Reply #7 on: September 06, 2010, 08:14:39 AM »
It looks like the wheels are not bent forward enough. Any plans to adjust them before the first flight?
Offline Leester
« Reply #8 on: September 06, 2010, 08:29:45 AM »
Yep, I need to check the plans for proper angle but they need it no matter.
Leester
ama 830538
Offline Leester
« Reply #9 on: September 12, 2010, 12:23:00 PM »
I adjusted the landing gear to a more acceptable possition. Also not sure how everyone else does it but on the wheel pants (from Tower belonged to a R/C plane ?? ) I made them fit the wheel space by cutting 3/8" dowell to size on each side of the wheel and drilling proper size hole for the axel. I c/a'd them to a ply backing which I epoxied to the wheel pants. Beats a ton of washers. Now to pin stripe the bottom of the wing. Who can I get the stick on graphics (Plane name and AMA number) from ?? My local source went out of buisness.  CLC ??
Leester
ama 830538
« Reply #10 on: September 12, 2010, 02:31:37 PM »
Looks good Leester!!! I like the Mo' Best.
Ping Louis Rankin. He should be able to fix you up. It might take him a day or two to reply to emails. He has been a little busy the past few days.  He was the CD for the MSC. y1
« Reply #11 on: September 12, 2010, 03:14:17 PM »
Hi Lee,
Turning out ot be a nice looker, and I am sure it will be a great flier!  Good Luck.
Big Bear
