  • June 20, 2025, 04:16:03 AM
Author Topic: K&B .45 Green head on Da Bay  (Read 1592 times)
Offline Curtis Shipp
  • AMA 753063 / Advanced Stunt Flyer Finally
« on: November 10, 2011, 12:22:06 PM »
I have a bid in on this motor. If anyone is bidding and wants it bad I will stop bidding. Let me know with PM. I do not need it any way. I am trying to corner the market and get rich with Fox .59's and other CL engines.  LL~
« Last Edit: November 10, 2011, 05:11:23 PM by Curtis Shipp »
Life is to short to be sour.
Re: K&B .45 on Da Bay
« Reply #1 on: November 10, 2011, 12:26:46 PM »
Curtis,
I thought you were going lectric? ::)
Glad you are getting a good engine. I had a .35 GH on a Flite Streak and it would go forever on about 2.5 oz of fuel. Only problem I had was setting the needle. No muffler and the stack was blowing right into my hand.  f~
« Reply #2 on: November 10, 2011, 01:35:37 PM »
I have a Cavalier coming that will run on 100% LiPo Electrons. I just saw the K&B .45 and thought I would use it on a Classic or Old time plane. I have 3 Fox .59's. One for a RSM Big Job and looking for another plane for one. I will also be making parts for the .59 to repair a long shaft for Charlie Reeves and one that I bought that turned out to be worn out. So if anybody needs 59 parts you better let me know. This will be a 1 time only deal.
Offline wmiii
« Reply #3 on: November 10, 2011, 02:44:20 PM »
What kind of parts for the Fox .59?
Walter
walter menges
« Reply #4 on: November 10, 2011, 02:58:20 PM »
Rods, pistons and pins, Re-bush cases. That is all I know of. Pistons will be .003 oversized so a rehone can be done to the cylinder. I may look at new cylinders as they are simple looking.
Offline andrew stokey
« Reply #5 on: November 10, 2011, 03:34:42 PM »
Curtis,
Missed you at Eldorado.  Lots of wives there so everyone had company to chat with.
« Reply #6 on: November 10, 2011, 03:43:15 PM »
I had to be in Memphis, Tn that weekend. Steel mills are a calling and they have money. Sorry we could not be there. I will be in Memphis again this weekend at the steel mill and going to the casino to see if I can make more money. I bet I would be better off not betting, but all work and little play makes me cranky. HB~>
« Reply #7 on: November 10, 2011, 04:16:49 PM »
Fox 59's.
I would like to know more about this engine?
CB
« Reply #8 on: November 10, 2011, 04:41:11 PM »
From what I read the 59 was Duke's first real production engine. I saw and heard Charlie Reeves Big Job on a 59 long shaft and decided to get some and run them. I think there are a lot of them out there that need TLC to keep them going. The long shafts break the crank case but with an extension you can make a short shaft work like a long shaft. I do not know if they run the same. The 59 reminds me of a diesel, gobs of torque with a great loud exhaust. So I will spend some time messing with them and making parts for them while I try to get another project going.
« Reply #9 on: November 10, 2011, 04:50:06 PM »
Curtis,
Thank you for your prompt and courteous reply. Informative also.
OK! seeing I have absolutely no interest in Fox 59's, I'll assist with your quest.
If I hear or see any, you will be told.
My guess, however, you'll be way ahead of me. Never know.
Any other engine you have interest in?
CB
« Reply #10 on: November 10, 2011, 05:06:45 PM »
Only the other project I am working on. >:D
« Reply #11 on: November 11, 2011, 09:30:41 AM »
Well, PM me if you want to keep it a secrete. I won't tell.
I have a devilish project going myself.   >:D
CB
