  • June 15, 2025, 11:17:48 AM
Author Topic: Ukraine Brass Steel lines  (Read 3141 times)
« on: February 19, 2023, 01:30:26 PM »
 Anyone have any experience with the Ukraine ready to use lines?
Has the crimped ends. 4 Strands rated at 50 lbs. .016.
Re: Ukraine Brass Steel lines
« Reply #1 on: February 19, 2023, 01:43:41 PM »
Yes.  They are excellent but you must keep them clean.  I was sent a set of the 3 wire when they first came out to test and I have been using them ever since.  He made some changes to the end crimping in later runs.  I had cut the ends off on the plane side and wrapped them ala AMA specs.  IMHO they are superior to steel.
I don't think there are any new sets available since the war.  Here is a link for the 3 line.
https://www.bing.com/images/search?view=detailV2&ccid=plVphicf&id=747D47B0A122260D7D88955BBBDB63385C8BB671&thid=OIP.plVphicfCP2k7kF_avGF0gHaHa&mediaurl=https%3a%2f%2fcontrollineparts.com%2f1840-medium_default%2flines-00145-in-70-feet-3-strand-50-lb.jpg&cdnurl=https%3a%2f%2fth.bing.com%2fth%2fid%2fR.a6556986271f08fda4ee417f6af185d2%3frik%3dcbaLXDhj27tblQ%26pid%3dImgRaw%26r%3d0&exph=953&expw=953&q=3+strand+control+line+parts&simid=608046994525352027&FORM=IRPRST&ck=59786F090304F8D094B6255C64C33A72&selectedIndex=0&idpp=overlayview&ajaxhist=0&ajaxserp=0
Online Lauri Malila
« Reply #2 on: February 19, 2023, 02:00:25 PM »
Yes they can be crimped but that would be my least preferred method.
My favorite method would be to wrap like AMA says, but with Kevlar thread & cyanoacrylate. Close second would be soldering, and then AMA copper wire wrapping and crimping.
With Kevlar wrapping there is practically zero risk of creating a hard point stress riser. But I don’t know if your rules accept it. L
« Reply #3 on: February 19, 2023, 02:48:02 PM »
   New rules, anything goes.
« Reply #4 on: February 19, 2023, 03:37:23 PM »
With the foldback wrap and heatshrink over the joint there is no need to solder anything.
Offline Crist Rigotti
« Reply #5 on: February 19, 2023, 04:29:46 PM »
Ditto to what Ken said.
Offline frank williams
« Reply #6 on: February 19, 2023, 05:40:30 PM »
Never trust any line ends that you didn't make yourself;
CA can wick into wires and create a hard spot.  Ask Jim Aron about even heavier leadout wire!
Solder can wick and create hard spots.  My yellow rat in a hole in the ground in SanAntonio iis an example.
The Ukrainian lines are fine.  I've had no problems with either the 4 or 3 strand.
I wrap with Radio Shack wirewrap.  Its a fine solid, colored insulated wire.  Easier to wrap than real fine copper.  I twist them off and leave about a quart inch of twist hanging out.  A short piece of heatshrink if desired.  NO CA.
Online Lauri Malila
« Reply #7 on: February 19, 2023, 06:41:41 PM »
I dare to disagree a little. Ca wicking between the strands of a single steel wire does not create any hard point to worry about. And neither does solder if you do it well. But with solder you must of course worry about flux remains, to have them well neutralized.
What does create a hard point is a stiff and heavy chunk of anything, and with thin Kevlar thread it’s easiest to make the binding gradually thinner away from the eyelet. It’s also a fractuon of the weight of copper wrap. It cannot be bad. L
Offline Tom Luciano
« Reply #8 on: February 24, 2023, 09:30:55 AM »
Paul,
  Some good info in this thread. We at the time had alot of questions about maintenance, etc.
Tom
https://stunthanger.com/smf/open-forum/ukraine-lines/
AMA 13001
Offline jfv
« Reply #9 on: February 26, 2023, 05:05:07 AM »
I've used the lines for a number of years and love them.  As noted, you need to keep them clean and dry.  Do not store them in a plastic bag as condensation may develop.  I also put a drop of oil in each crimp to prevent rusting.
Jim Vigani
Offline Mike Palko
« Reply #10 on: February 26, 2023, 06:10:56 AM »
I spoke to Ruslan recently and can confirm he can no longer produce lines because of the war.
« Reply #11 on: February 26, 2023, 09:47:57 PM »
Thanks guys.
4 strands had me questioning them.
I will take them 4 a spend. 😉
Offline Frank Wadle
« Reply #12 on: February 27, 2023, 08:45:32 AM »
If someone needs lines, just contact me.
4 strand steel, brass plated, diameter 0,42mm.
Made in western europe :-)
Best regards
Frank
« Reply #13 on: July 16, 2023, 06:48:36 PM »
Anyoe have advise for re-making the line ends AMA style on these brass steel lines. I cut the crimped ends off and instanly lost 6" becaused they unwrapped badly. Also had allot of problems wrapping the line twice around the eyelet. After I finished the wire were seperated south of the wrapping wire so, I don't trust it. This stuff is very stiff and springy. Do you CA glue the wire before cutting? How did you deal with it?
Offline Tom Luciano
« Reply #14 on: July 16, 2023, 07:57:49 PM »
MM,
Yes, CA before cutting. I found out the hard way too!
Tom
AMA 13001
« Reply #15 on: July 16, 2023, 09:10:56 PM »
CA
