  • July 18, 2025, 12:32:13 PM
Author Topic: Lead outs at bell crank  (Read 3647 times)
Offline RC Storick
« on: October 13, 2014, 12:06:06 AM »
How I wrap leaouts
Re: Lead outs at bell crank
« Reply #1 on: October 13, 2014, 12:15:51 AM »
"This video is private"
Offline RC Storick
« Reply #2 on: October 13, 2014, 12:29:35 AM »
« Reply #3 on: October 13, 2014, 01:31:09 AM »
Nice video, I am fixing to do a set of leadouts today if my supplies arrive like they should. Its been raining for a couple days now so I can't paint or do my farm work. I'm happy you did this to refresh my mind on the proper procedure. H^^
« Reply #4 on: October 13, 2014, 01:59:38 AM »
How I wrap leaouts
  That will work OK, but I usually attach the leadouts to the teardrop first with my usually line-tying jig, then assemble the bearing/teardrop/screw afterwards.
Offline Dick Pacini
« Reply #5 on: October 13, 2014, 06:34:56 AM »
Where do you get the teardrops?
AMA 62221
Offline RC Storick
« Reply #6 on: October 13, 2014, 08:27:37 AM »
This was just the proper procedure of wrapping. I don't have a holding fixture. I could have use the Jim Lee clothes pin but not everyone has that.
« Reply #7 on: October 13, 2014, 10:34:22 AM »
I make them from PC board. Pretty easy. I make a fixture for my mill and can hack them out pretty easily.
Online Gerald Arana
« Reply #8 on: October 13, 2014, 11:26:59 AM »
Hey Sparky,
Ever use one of these? Its a "bobbin" and it is used in "Fly" tying (for fishing). Sure makes that laborious task of wrapping the lines easy.
Plus, you can buy copper wire on sewing thread size spools (and different sizes) at the tackle store!
Yeah, yeah, I know you're not a fisherman!  LL~ LL~ LL~ LL~
Good luck, Jerry
PS: That is lead wire I have on it just to show how big of a wire can be installed.
« Reply #9 on: October 13, 2014, 01:33:45 PM »
From looking at my scores.
« Reply #10 on: October 13, 2014, 06:53:48 PM »
   I thought you were going to say,"from my pillow!"
« Reply #11 on: October 13, 2014, 07:57:03 PM »
This was a right goodie of a video and something that I needed to see. Thanks for taking the time to do that. Enjoyed the slow neat wrapping technique.
Offline RC Storick
« Reply #12 on: October 13, 2014, 08:06:48 PM »
You are a VIP at CL Craftsman you can view the other end  Lead out block in the complete Continental build string.
« Reply #13 on: October 13, 2014, 08:21:26 PM »
I only learned to do this about three planes ago. It's nice to be able to watch and make sure I am doing it all correctly. And my copper spool which was passed down to me said 28g, but when I bought some new 28g it was thicker. Now I know to get 29g. Thanks.
Offline Jim Svitko
« Reply #14 on: October 13, 2014, 09:16:05 PM »
I use 1/8 thick Delrin.  A bit tedious to make them by hand, filing the groove with a needle file, but worth the effort.  Instead of wrapping the lines, I use the  sleeves and crimping tool from McMaster-Carr.
Offline Steve Fitton
« Reply #15 on: October 14, 2014, 07:39:21 AM »
Hey Jim,
What tool/sleeves from McMaster?  I hate wrapping leadouts and would much rather crimp.
« Reply #16 on: October 14, 2014, 08:02:23 AM »
Leadout wrapping has ALWAYS been private. LL~ LL~
Offline Jim Svitko
« Reply #17 on: October 14, 2014, 01:19:18 PM »
Hey Jim,
The crimp tool is McMaster-Carr part number 3632T17.  It will crimp only one size of sleeve to fit 1/32 wire.  It is an expensive item but since I also hate wrapping it was worth it to me.  There are crimp tools available for multiple size sleeves/wire if you think you might use more than one size.
The sleeves are McMaster-Carr part number 3755T11.
I bought these items years ago and no doubt they are more expensive now.  However, the proper crimp sleeve and tool are essential to making a reliable connection.
I use the crimped sleeves on the leadout exit end as well, wrapping the wire around a brass eyelet.
« Reply #18 on: October 15, 2014, 08:12:28 AM »
Thanks for the info Jim!
Are you using Morris leadouts or the gold anodized Sullivan stuff?
Offline Jim Svitko
« Reply #19 on: October 15, 2014, 09:06:48 AM »
I use 1/32 stainless wire from McMaster-Carr.  More flexible than the Sullivan wire but maybe more prone to individual strand breakage as it is 7 X 7.  I am using a Delrin leadout guide so maybe that will help prolong leadout life.
The type of wire may not matter that much.  Before I used this teardrop/crimp system I made up two test specimens.  One with the Sullivan, one with the McMaster-Carr wire. Both held a 50 pound dumbbell with one sleeve.  Being somewhat risk adverse, I used two sleeves for each connection on the plane.
I have only one plane with this set-up, my latest Oriental.  Unless I experience a failure I intend to use it from now on.  I had been using solid 1/32 music wire leadouts.  Never had a problem with them but I was always scraping them on something and worrying about bending them.
« Reply #20 on: October 15, 2014, 02:15:04 PM »
Hey Jim,
   If you are using my style bellcrank, I strongly urge you to use conventional wrapping. Part of the durability is that there are no flex points in the wire, achieved by running the wrap on to the pointy end of the teardrop eyelet, so the wire and the teardrop move as one piece. You can't do that with a crimp, you will wind up with a flex point right between the teardrop and the crimp. Even the slight drag on the teardrop as you move the controls will cause a deflection right there, ans since it must be as close to the eyelet as possible to ensure it stays in the groove, even tiny amounts of flex will apply lots of stress.  That just recreates the problem with the "tubing sleeve" system that is notorious for failing.
    If you must crimp the wire, you might want to cut of the tip of the teardrop, drill a small hole in the resulting flat spot, then insert a small (maybe .028 x 1/4") bit of music wire, then apply the crimp over that in additional the leadouts. The wire will have to be short enough to be buried entirely inside the crimp, if not, you will have the tail end poking out, and creating yet another point of flexure. You can't avoid the point of flexure at the end of the crimp, but at least you don't want to make is worse.
    The teardrop eyelet and leadouts need to move as one piece with only the flex allowed by the wire wrap.
Offline Jim Svitko
« Reply #21 on: October 15, 2014, 03:57:31 PM »
Brett, thanks for that tip.  I also had concerns about flex at the tip of the teardrop but could not come up with anything to get around it.
