Oil up those 5-40's good before you screw them into your ST, because they're NOT the exact same thread. The OEM's are METRIC, 3m-.6....but awful close to 5-40. The head size is bigger and may interfere in the counterbore in cylinder heads. But at least they'll use a 3/32" hex (Allen) wrench, same as 4-40's, FYI. They work fine. Lots of ST and OS engines are out there using 5-40's. Tom Lay used them on the early ST engines like yours, but the G.51's use 3m-.5, which is apparently a newer metric standard. Confusing?
I'm sure Phil meant Socket Head screws and not "hex head". Absolutely the way to go, vs. Phillips or JIS heads.
