  • June 22, 2025, 09:35:56 AM
Author Topic: New Cardinal  (Read 2189 times)
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
New Cardinal
« on: March 04, 2010, 04:53:15 AM »
Ok here it is... nearly 2 years in the making... Brodak Cardinal with a OS FS52 four banger.  Had to take nearly 2" off the nose to get the CG right.  But unfortunately that meant no room for a tank.  So for the moment I have a 4oz Hayes clunk on the inside, but may build a custom tank later to fit behind the engine.
The prop is a 10x7.5 three blader... not sure how this will go... weight is 50 oz.  Paint job is all epoxy enamel, no plastic.
Engine is almost run in... final run in needs to be done before I can fly it.
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Re: New Cardinal
« Reply #1 on: March 04, 2010, 05:54:29 AM »
The plane looks great.  I see you have your tank on the inboard side of fuse.  Let us know how it works.   H^^
Offline Bill Hodges
Re: New Cardinal
« Reply #2 on: March 04, 2010, 07:41:15 AM »
Warren:
Great looking plane.  I love that paint scheme.
Bill Hodges
Bill Hodges
AMA 12450
Offline Matt Colan
Re: New Cardinal
« Reply #3 on: March 04, 2010, 03:12:36 PM »
Lookin good!  That paint scheme looks familiar...
Online Paul Taylor
Re: New Cardinal
« Reply #4 on: March 04, 2010, 06:22:46 PM »
Hey Warren,
I will be right over to pick it up and test it out for you!!! <=
I wish.
I like the pants or what ever you guys down under call them. H^^
Re: New Cardinal
« Reply #5 on: March 04, 2010, 06:24:45 PM »
She's a looker Warren 8)
Offline Greg L Bahrman
Re: New Cardinal
« Reply #6 on: March 04, 2010, 06:37:24 PM »
Cool.......OS52 will fly a plane twice that size........you will have enough power.....Yee Haa
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Re: New Cardinal
« Reply #7 on: March 04, 2010, 06:51:39 PM »
Warren, I have seen plenty of profiles with the tank mounted on the inboard side. If the tank is plumbed right, it seems to make NO DIFFERENCE. But that said, you gots to put your setup the way you feel comfortable. Please keep us posted on the os Max 4 stroke. Nice to see someone using something different, and more sophisticated besides the usual LA 46 on the old profile.
  • AUS-14782
    • My Home Page
Re: New Cardinal
« Reply #8 on: March 05, 2010, 02:17:45 AM »
Thanks guys, hopefully I will fly it tomorrow. I will keep you posted.
The paint scheme is copied from the Strega ARF, it was more about me learning to paint models and make good curves rather than using plastic film and trim sheets.
Yes, we do call them wheel pants Paul!
The motor starts real easy... first flick!  I'm not sure about the prop though... is it big enough?
Cheers
Warren Leadbeatter
AUS-14782
Re: New Cardinal
« Reply #9 on: March 06, 2010, 08:43:08 PM »
Howard would call those "wheel trousers".....or maybe "wheel knickers"?  LL~ Steve
Edit: The inboard tank might be a great thing for a 4-cycle, what with their rep for weak suction.
« Last Edit: March 07, 2010, 07:49:37 PM by Steve Helmick »
