The Babe Bee really shouldn't stall in a loop. A Babe Bee will fly inverted for a little while before it quits. I'm sure there could be numerous reasons here as to why its stalling. The Jumping Bean is a very maneuverable plane. Therefore, the loops should be rather quick. I had a problem with a Jumping Bean recently. I had blocked the airway to the intake due to the rubber band that holds the gear in place. I had a very large rubber band and this was wound around the knob on the firewall multiple times causing the air blockage. One thing I would check for is that all gaskets are intact with this engine. A rebuild kit is easily obtained and this can save a lot of headaches. I like to screw the needle all the way in, pressurize the top vent while holding my finger on the bottom to check for leaks. This can tell if the tank venturi gasket is making the correct seal. This is if the needle valve is seating correctly of course. You can listen and hear where the air is coming from. I've also had air leaks from the backplate screws. These leaks can happen in the metal an also plastic tank backs. Cracks can form in either style which are not noticeable to the eye until you pressurize the tank. I use a drop of oil on the heads while pressurizing to detect if the screws are leaking. A plug even though it appears to be glowing can also be the culprit. Its amazing how a new plug performs. You didn't mention any particular fuel you were using or nitro content. I prefer the higher nitro in the 25%-35% as I've found this keeps things going quite well. Your problem may even be a simple replacement of the pickup tube. As they age they don't seal well around the nipple and they usually don't stay in the corner. I found Davis Diesel tubing to work very well and it retains its flexibility. In the event the plane is quite aged, make sure no paint chips are getting sucked off the firewall and getting wedged in the venturi screen. You also didn't mention the orientation of the cylinder to the plane. I prefer the cylinder to be laying horizontally and to the outboard wing. I've had the cylinder in the vertical position and they would drown out in the outsides like a Fox burp so to speak. Let us know your findings. Ken
