  • July 17, 2025, 09:35:14 PM
Author Topic: lead outs  (Read 1047 times)
Offline Bootlegger
lead outs
« on: December 18, 2014, 04:49:39 AM »
 I am building a Jr Flite Streak and am seeking a way to set the lead outs without making them adjustable, I don't want the added weight.
  How would you go about setting the lead outs, then attaching them permantely to the tip?
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: lead outs
« Reply #1 on: December 18, 2014, 06:04:13 AM »
I would run the numbers using LineIII or just put them about 3/4 inch behind the CG (center of both lines).
Online Geoff Goodworth
Re: lead outs
« Reply #2 on: December 18, 2014, 07:54:00 AM »
i use pop rivets with the mandrel knocked out as the guide. Press the flange into the balsa tip and cover with a little bit of epoxy continuous over the rivet shank.
Offline Bootlegger
Re: lead outs
« Reply #3 on: December 18, 2014, 08:35:33 AM »
 Bob, I don't unnerstan about the "center" of both lines, could you 'splain in more detail?
 Thanks a lot
Gil Causey
AMA# 6964
Online Motorman
Re: lead outs
« Reply #4 on: December 18, 2014, 08:41:12 AM »
Measure the distance between the two lines and divide by 2, this center point is your tether.
Offline Bootlegger
Re: lead outs
« Reply #5 on: December 18, 2014, 10:13:13 AM »
 Thanks M M, now is this  using the measurement shown on the plan or the 3/4" behind the c/g that Bob was reffering to?
Gil Causey
AMA# 6964
Re: lead outs
« Reply #6 on: December 18, 2014, 11:38:59 AM »
I never had any problem with the lead outs per the plans.
Offline Bootlegger
Re: lead outs
« Reply #7 on: December 18, 2014, 12:59:47 PM »
 Thanks guy's I appreciate the help...
Gil Causey
AMA# 6964
