  • July 21, 2025, 01:27:03 PM
Author Topic: Lead out wraps  (Read 1396 times)
Offline Tom Strom
Lead out wraps
« on: May 20, 2011, 10:10:16 AM »
I know this has probably been covered somewhere, but I can't find it.  What size copper wire do you use to wrap leadouts, and where do you get it?  Can't seem to find anything that is not coated with something.  I found some real neat wire at Radio Shack, but it has a thin coating on it for insulation. (magnet wire)  Or is that OK?  Sorry for the questions, but figured someone would answer without laughing too hard at me.
Tom
Re: Lead out wraps
« Reply #1 on: May 20, 2011, 10:21:48 AM »
Hi Tom,
The Radio Shack wire is fine.  I use the red spool for "UP", and the green spool for "DOWN".
Big Bear
Offline Tom Strom
Re: Lead out wraps
« Reply #2 on: May 20, 2011, 10:37:48 AM »
Great, thanks Bill.
Tom
Offline Jim Thomerson
Re: Lead out wraps
« Reply #3 on: May 20, 2011, 04:48:32 PM »
I also use beading wire from Hobby Lobby.  They have several different kinds, so you can get one, or more, to suit you.
Re: Lead out wraps
« Reply #4 on: May 20, 2011, 05:39:04 PM »
I think I have the most expensive leadouts known to man. I got some pure silver speaker cable from Cord - Sivler carnival $ 50 Per Meter, stripped it down and used the wire out of that, its thicker that regular copper I normally use, solders easier.
Not for everyone, but I wanted to try something different.
Offline Frank Imbriaco
Re: Lead out wraps
« Reply #5 on: May 20, 2011, 06:19:18 PM »
After stripping insulated wire for decades, I recently discovered that Tom Morris sells  28 guage copper wrapping wire(Cat. # WIRE-28). It comes on a 1/4lb spool and sells for $6.95(excluding s&h).
 ctmorris@cableone.net
Offline Chucky
Re: Lead out wraps
« Reply #6 on: May 20, 2011, 07:01:16 PM »
I've used Radio Shack magnet wire and even tried .028 copper wire from the beading section at a local Michael's craft store.  Both were convenient but not very cost effective.  McMaster-Carr seems to have the best prices I've found online.  A 1/4 lb spool of .025 tin-coated copper wire is well under six bucks.  Slightly thinner, but works just fine and the tin resists corrosion.    http://www.mcmaster.com/#oxygen-free-copper-wire/=ce60nz
Chuck Winget
Offline Tom Strom
Re: Lead out wraps
« Reply #7 on: May 20, 2011, 08:50:00 PM »
Thanks to all for the reply.  I forgot about the Morris stuff.  I bought the Radio Shack wire, and will give it a try.  Thanks again.
Tom
Re: Lead out wraps
« Reply #8 on: May 20, 2011, 10:43:45 PM »
Tom, you know that soldering the wraps is now out of vogue right? just wrap them, maybe a drop of CA, then heat shrink,
Offline Tom Strom
Re: Lead out wraps
« Reply #9 on: May 20, 2011, 11:04:29 PM »
Yep.  Thanks Mark.  I wrapped and epoxied my Nobler, and Flite Streak.  But it has been a while, and I was out of copper wire.  Last stuff I had I got from Todd's dad Mac.
Tom
Offline Bill Heher
  • Fix-it
Re: Lead out wraps
« Reply #10 on: May 20, 2011, 11:32:41 PM »
Jim at CLC has Tom Morris line wrapping kits for a couple bucks. It has instructions, wire, and 4 thimbles so you can do 1 set of lines or a pair of leadouts.
I have plenty of wire- I always run out of thimbles, can't seem to find 1 once I drop it
Bill Heher
If it's broke Fix-it
Offline Don Curry AMA 267060
Re: Lead out wraps
« Reply #11 on: May 21, 2011, 08:52:29 AM »
I purchased wire at a fly tying shop. They have it in many colors and it is only about $2 a roll and they have spool bobins,cutters, clamps ect. lots of stuff we can use.
Don
Re: Lead out wraps
« Reply #12 on: May 21, 2011, 09:06:30 AM »
MBS Model Supply carries two types of wrapping wire.  One has a coating and the other doesn't.  Check out his site for other stuff also.   H^^
