  • July 17, 2025, 09:04:51 PM
Author Topic: blank  (Read 2630 times)
Online Motorman
blank
« on: December 28, 2017, 04:57:45 PM »
blank
« Last Edit: December 06, 2021, 08:28:59 AM by Motorman »
Offline George Truett
Re: lead out wire
« Reply #1 on: December 28, 2017, 07:20:41 PM »
Offline Brent Williams
Re: lead out wire
« Reply #2 on: December 28, 2017, 07:55:49 PM »
Here is another option.  A few planes around these parts have been built with this cable.
This 1/32" (.031")  3x7 cable is very flexible which is nice to help prevent the random hanger rash induced kink in your leadouts.
- 3x7 hollow core has three strands of wire rope with seven wires in each strand, formed helically around a hollow core
- 3x7 hollow core is flexible and fatigue-resistant
Loos Stainless Steel 302/304 Wire Rope, 3x7 Hollow Core, 1/32" Bare OD http://www.loosco.com/upload/pdf/SC03137.pdf
https://www.ebay.com/itm/Loos-Stainless-Steel-302-304-Wire-Rope-3x7-Hollow-Core-1-32-Bare-OD-100-110/332181414900?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Online Howard Rush
Re: lead out wire
« Reply #3 on: December 28, 2017, 08:30:32 PM »
Who has .032" 7 strand stainless cable?
I got several types from McMaster-Carr.
Re: lead out wire
« Reply #4 on: December 28, 2017, 09:07:25 PM »
  What is your concern with .027" cable" ? Do you really think the .005" would make a big difference? Remember, you are flying on .018" lines. Each lead out is nearly .010" larger.
Offline Allan Perret
  • Proverbs
Re: lead out wire
« Reply #5 on: December 29, 2017, 09:48:28 AM »
I use the .027" from McMaster Carr, it is rated at 110# breaking strength.  Flexiblity is good, just right for me.  Its 7 strand, not 3x7.  Comes from Loos Cable, confirmed this with Loos.
Allan Perret
AMA 302406
Slidell, Louisiana
Online Howard Rush
Re: lead out wire
« Reply #6 on: December 29, 2017, 09:56:48 AM »
I used them. I got different types— maybe not all from McM— to pick the smoothest. The 7-strand stuff was pretty much all the same.
Re: lead out wire
« Reply #7 on: December 29, 2017, 01:12:13 PM »
You can also get Sevenstrand (brand) cable from Cabela's, but the problem is that they rate it by pound test and not diameter. If you have a Cabela's store nearby, take a micrometer and you're good. If you have to order online, not so much. Make sure you do NOT get the plastic coated version.  D>K Steve
Offline Jim Svitko
Re: lead out wire
« Reply #8 on: January 08, 2018, 05:29:53 PM »
Regarding the stranded 0.031 cable:  1 X 7 and 7 X 7 are available from sources such as McMaster-Carr.  Which of these two is preferred?
The 7 X 7 is more flexible but the strands are thinner.  Would it be more susceptible to individual strands fraying and breaking where it goes thru the leadout guide?  As for the 1 X 7, it is stiffer and coarser.  Would it tend to "saw" thru the leadout guide, especially if the guide were nylon?
Online Robert Zambelli
Re: lead out wire
« Reply #9 on: January 08, 2018, 05:42:51 PM »
This company has some stainless multi-strand cable.
I've used it many times in industry - top quality stuff.
  https://www.savacable.com/pages/LowStretchCable.html
