  • June 27, 2025, 04:03:25 AM
Author Topic: lead out legnth  (Read 840 times)
Offline Phil Goldberg
  • Just completed this PDK Buster 45
lead out legnth
« on: July 15, 2015, 11:16:19 PM »
Is there any suggested length that lead outs should extend from the wingtip?
Re: lead out legnth
« Reply #1 on: July 15, 2015, 11:22:07 PM »
Mine tend to extend about four inches when their finished.  You want them to be long enough that they don't get sucked into the wing at their shortest extent -- I don't know of any hugely important reason that they need to be kept snubbed short.
Re: lead out legnth
« Reply #2 on: July 15, 2015, 11:30:02 PM »
Having had a termination (eyelet) damaged once, I tend to make mine project a bout an inch and a half or two inches more than they need to so if necessary they could be shortened  by that much if necessary to make a repair to the leadout end without completely replacing the leadout.  I guess I'm a little paranoid about this kind of stuff but I sincerely believe in the old "saw" "If anything can go wrong, it will!".
Offline goozgog
Re: lead out legnth
« Reply #3 on: July 16, 2015, 03:01:40 AM »
  Hello Phil,
   I'm doing what Randy does,
and for the same reason.
I keep them about 4.5 " beyond
the wingtip so that I could make
a repair.
   The only problem with longer
lead outs is that they love to trap
themselves in the car door.
I usually tuck the ends back inside
the adjustment slot.
Cheers!
Keith Morgan
Online John Park
  • Agricola
Re: lead out legnth
« Reply #4 on: July 16, 2015, 06:19:44 AM »
Back in the old days of solid leadouts which were spaced as far apart as the length of the bellcrank, we never had to worry about the lines snagging one another where they were connected to the leadouts, but since I took to adjustable, closely-spaced flexible leadouts I've always been happier if the connections are no more than three or three-and-a-half inches beyond the leadout guide at neutral.  This is probably erring on the safe side, but it gives me peace of mind.
Mike Griffin
Re: lead out legnth
« Reply #5 on: July 16, 2015, 08:40:45 AM »
You will get answers all over the spectrum on this .  I use flexible cable leadouts and I am like Randy, I have plenty of length to play with.  I cut mine to 5 inches.  I have not used solid, stiff wire leadouts in years but I would say they would need to be shorter due to the susceptibility of getting bent.
Offline peabody
Re: lead out legnth
« Reply #6 on: July 16, 2015, 08:54:13 AM »
Some vary the length significantly ( like 8") .
Matched lines, they don't encounter flipping the lead outs.
