I don't like to use these to attach my gear doors to my landing gear wire as they always seem to end up moving around. I've tried other approaches but they are not always easy to do (soldering on wire clips, etc.) and don't necessarily work better. What is a simple way of mounting thin plywood gear doors? Suggestions?
Scott
Scott,
Unless you make the door part of the gear wire, not removable in that case, there probably isn't what would be called a "simple" way. If there is, I'd like someone to share it with me.
![Layingdown LL~](https://stunthanger.com/smf/Smileys/classic/side_laugh.gif)
I use four light tin tabs easily made or could be made from brass stock. They look like your nylon piece. I solder them to the gear wire then solder small nuts to the tin to except the bolt from the plywood side.
I see other models where the bolt heads are visible, shinny and look nice. Just like mine.
![Grin ;D](https://stunthanger.com/smf/Smileys/classic/grin.gif)
Doesn't take long actually to solder eight of them, four per gear wire. Or not solder. That will work also, just bolt them up!. They might move around without the tin soldered? I solder to prevent this.
I have a few builds where I show this gear construction in detail. The ARGO and the Mig-3. Both builds and photos should be over at CFC Graphics vendor's corner.
I hope this helps.
CB
