  • July 07, 2025, 04:21:29 AM
Author Topic: ....Maskin Tape...  (Read 1515 times)
Offline Bootlegger
....Maskin Tape...
« on: August 04, 2008, 01:30:48 PM »
 :!  Guy's what type maskin tape do you use when you are tapin with the paper and tape dispenser/
  I sure don't want to peel paint up or tear the paper when I remove the tape and paper...
   Got any suggestions ??? #^ n~
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: ....Maskin Tape...
« Reply #1 on: August 04, 2008, 02:32:05 PM »
I don't use the tape and paper thing, but I use drafting tape for masking. I buy it in 3/4" wide rolls and cut the width that I need. I have never had it pull up paint as it seems to have just the right amount of stick to do the job. I do generally wait at least over night before removing it in order for the edge to harden. It looks just like masking tape, but works much better. I only use 3M brand.
« Reply #2 on: August 04, 2008, 02:37:41 PM »
I use the Mylar tape from automotive paint stores.  Usually 1/4" wide, then I use 3M "blue" painter's masking tape to stick down the rest of the paper masks (I use 8.5 X 11" computer printer paper because it handles easier).  The Mylar gives a clean edge.
Floyd in OR
Offline Jim Treace
  • 1979 600 Aerostar N79JT
« Reply #3 on: August 04, 2008, 03:33:02 PM »
I use 3M Blue (Orange label) Delicate (only use the Delicate orange label tape), to attach the paper and use this in the paper/tape machine. Get this at Home Depot/Lowes/Ace Hardware, etc.
For fine masking, hard to beat the tape supplied by Finesse Pinstriping, Inc.
http://www.finessepinstriping.com/  "The EDGE" is the best.
But I am no expert by any means, maybe others have better suggestions.
Jim
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
Offline Bootlegger
« Reply #4 on: August 05, 2008, 08:17:02 AM »
 n~          Thanks guy's I 'ppreciate the help.... #^
Gil Causey
AMA# 6964
