I like the Lee venturis, they're longer. Which I think reduces turbulence in the airflow. True. Maybe. Like I said, I think it helps. Lately I've been using .072 openings in the the 46 and the FP40s. Also possible to go smaller in both engines. In years past I used the big hole, .083. But the smaller opening, reduces power, better suited to the size planes I fly. Vectors, Twister, Cardinal, Tanagers and the like. Lately I've been fiddling with venturi sizes as a way to tune power appropriately to the needs of the airplane/engine combo. Dunno why it took me so many years to realize the obvious. Smaller venturi, same as closing down the throttle. The needle, in that case, is more of a mixture control, as opposed to a surrogate throttle fraught with bugaboos. In other words, the power might be right when the engine is not running in an optimum mix. Smaller venturis cut down fuel consumption as well. My contest veteran veteran Tanager/Falcon would use every drop of 6 ounces to do the pattern powered by a sloppy sloppy rich LA46. Trying to duplicate this mild/friendly setting in my recent ARF Vector left me short on fuel, couldn't get a six ounce tank in the tank space. The smaller venturi solved that, throttling back the power as well. Seems like this will be a useful tuning.
