  • July 18, 2025, 12:36:07 PM
Author Topic: kit info  (Read 2391 times)
Offline cory colquhoun
kit info
« on: January 22, 2017, 01:48:25 PM »
anyone tell me what the buildrightfly kits are like,the profile nobbler looks choice,but a bit pricey by the time it lands here in aus.
 cory
Offline Ken Burdick
Re: kit info
« Reply #1 on: January 22, 2017, 01:57:08 PM »
The kits are excellent. I have built a few and all parts fit perfectly, great wood selection and the online building instructions are very complete.
Online Gerald Arana
Re: kit info
« Reply #2 on: January 22, 2017, 01:58:46 PM »
Cory,
Let me be the first to tell you that the Umland kits are the best of the best! Nobody is making "better" ones although some are just as good.
I have several. All I need is to build'em!
Cheers, Jerry
Offline Russ Main
Re: kit info
« Reply #3 on: January 22, 2017, 06:03:32 PM »
Exactly what the others have said, in addition if you have a question he is more than willing to help at any point of the build. You can't buy one and be done! You will want the fleet! :)
Russ
Re: kit info
« Reply #4 on: January 22, 2017, 06:05:09 PM »
As Russ says,  if I had the $$$ and room I would have every one of Walters kits.
Offline Brent Williams
Re: kit info
« Reply #5 on: January 22, 2017, 07:05:53 PM »
If you are not opposed to scratch building, Steve Moon @ Ultra Hobby Products has plans for a profile Gieseke Nobler that uses a combination of balsa/foam/plywood.
http://www.ultrahobbyproducts.com/plans-page-3.html
Online John Rist
Re: kit info
« Reply #6 on: January 22, 2017, 08:33:57 PM »
I am confused - What is the purpose of a profile Nobler.  I would think that if you want a profile ship that you would want a modern design.   However if it just has a Nobler outline and the airfoil of a morderan stunter it would make sense.   Just woundering.   ???
PS I have not built a Walter kit however I have seen them.  They look really good.   I do have one of his kits on order.  Looking forward to having a great build.   #^
Offline pat king
    • PDK LLC
Re: kit info
« Reply #7 on: January 22, 2017, 08:45:34 PM »
Walter's kits are the Rolls Royce of today's kits!
Pat
Pat King
Monee, IL
AMA 168941
Re: kit info
« Reply #8 on: January 22, 2017, 09:17:28 PM »
 cory
    The pricey part is because Walter puts a LOT of work into engineering the kit, doing the cad work, and pulling the project together. The wood is always first rate and that ain't cheap anymore. Add in that the kits aren't made in great numbers like kits in the old days, and that affects price. But they are worth every penny. I know you mates down under are at a disadvantage for getting these and other kit makers products from this hemisphere, but such is the way of the world now. Maybe science can clone Walter and send a copy of him down there to take care of your needs?? Maybe Walter can start to franchise out BuiltRight kits? Like some of the others, I have been stashing some of Walter's fine goods for "one of these days" and just have to decide which one to do first.
Online Fred Underwood
Re: kit info
« Reply #9 on: January 22, 2017, 09:21:27 PM »
One fellow in the PNW uses a profile Nobler to fly in Classic and then Profile, of course with the classic airfoil not modernized.
Scroll down a couple here
http://flyinglines.org/planes.9.16.html
Fred
352575
Re: kit info
« Reply #10 on: January 22, 2017, 10:55:29 PM »
cheers gents i get the picture, im gonna get one
Re: kit info
« Reply #11 on: January 23, 2017, 01:07:17 AM »
     what do you think would be a more modern looking profile that they make, to accommodate .35 that i wish to use
cory
Offline Terry Caron
Re: kit info
« Reply #12 on: January 24, 2017, 08:13:54 PM »
Cory, take a look at the Doodlebug, Magician and Mackey .35 size profiles.
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Re: kit info
« Reply #13 on: January 24, 2017, 08:23:38 PM »
will do thanks Terry
Re: kit info
« Reply #14 on: January 24, 2017, 09:16:07 PM »
Walt just got back to me, and with the exchange rate, kit exceeds $300 au a bit more than I want to spend as were new to the sport.was wondering would my OS. .35 max s be enough to power a Brodak Cardinal
Re: kit info
« Reply #15 on: January 25, 2017, 07:04:31 PM »
Get plans for a Sig Twister. Very easy to build and perfect for your motor. Plans can be found free on plans sites or maybe someone one here has a set.
Re: kit info
« Reply #16 on: January 25, 2017, 07:13:41 PM »
Found one
Re: kit info
« Reply #17 on: January 25, 2017, 08:52:56 PM »
Found one
thanks for the input, i dont mind the look of that at all.and i can scratch build cheers
cory
