  • June 22, 2025, 07:01:49 AM
Author Topic: K&B 8011 needle valves and spraybar  (Read 946 times)
Offline Scott Jenkins
« on: February 11, 2008, 11:03:11 AM »
Looking for Spray bar .156 dia. and needle valves for a K&B 40 Model 8011 or 4011. Who has them seem to remember some one has them.
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
Offline Leester
Re: K&B 8011 needle valves and spraybar
« Reply #1 on: February 11, 2008, 11:36:52 AM »
Try Randy Smith in the engine forum
Leester
ama 830538
Offline George
  • Love people, Use things.
« Reply #2 on: February 11, 2008, 12:54:53 PM »
If Randy doesn't have them, try Brodak.
My K&B .40's came from Brodak's.
George
George Bain
AMA 23454
« Reply #3 on: February 12, 2008, 09:52:23 PM »
I bought some K&B NV assemblies (#2918, I think) from MECOA/RJL/K&B a few years ago. There aren't that many K&B engines that still use this assy. They're pretty close to the early K&B units, but aluminum knob instead of brass...much like the later Veco units. The clicker spring is a PITB to install, so I prefer the Randy Aero/Nelson units. They are the best you can get, without question, and the same diameter (.156").  Randy does sell several lengths, and some that are smaller diameter, too, for OS and Fox's.  y1  Steve
