  • July 05, 2025, 11:09:30 PM
Author Topic: K&B .28 control line engines on the way  (Read 5156 times)
Offline bob jablonski
« on: October 07, 2015, 08:17:20 AM »
After many emails and phone calls the K&B .28 control line engines are here. Based on the .28 K&B Sportster engine but with a K&B installed C/L venturie and a tongue muffler. Weight, just under 10 oz with muffler. Price is a bit more then I was hoping. Introductory price is $89.95. I should have the engine and ordering info on my website by Friday.  The .40 engine is next
Mr. Bob
Countyline Hobbies
Grovertown, IN574-540-1123
countylinehobbies@yahoo.com
www.countylinehobbies.com
Like us on facebook
Online Motorman
Re: K&B .28 control line engines on the way
« Reply #1 on: October 07, 2015, 08:29:00 AM »
Is this the one with the chrome plated piston running in a plain aluminum bore?
Offline Douglas Ames
« Reply #2 on: October 07, 2015, 10:12:22 AM »
Are these reworked MECOA's?
AMA 656546
Offline Dane Martin
  • heli pilot BHOR
« Reply #3 on: October 07, 2015, 10:35:31 AM »
Thanks Mr Bob! That's still a pretty good price. Are they available now? I guess i could check your website... Lol
Btw, i need to hurry up and build that sig akromaster i got on your father's day sale....
Duh... I just saw the part about Friday. I'll check then
« Reply #4 on: October 07, 2015, 10:46:47 AM »
Specifications say chrome piston and cyl. They will be on the web site Thursday. Picture of  the new engine may not make it on till Friday.
« Reply #5 on: October 07, 2015, 10:50:39 AM »
These are 100% made by MECOA ,(aka made in USA)
« Reply #6 on: October 19, 2015, 09:02:35 AM »
Here is a picture of the engine.
Mr. Bob
Countyline Hobbies
Grovertown, IN.
574-540-1123
www.countylinehobbies@yahoo.com
Like us on facebook
Offline Carl Cisneros
« Reply #7 on: October 21, 2015, 08:41:35 AM »
I have one of the K&B 28's and a 65 and they are very good motors.
They DO LIKE OIL in their fuel.  More castor than syn.  I run mine with 22 to 25% oil
depending on the season. (cool weather low oil, hot weather more oil)
both are in RC models and have had more than 15 gal. of fuel thru them.
I do have a 28 that i converted over to CL for a build over the next couple months when
I amhome recuperating from hip replacement surgery in about a week and a half.
They also like a bit larger prop that what would be used on say an OS of equal size. They are torquers.
you really can not go wrong with these little gems.
Carl R Cisneros, Dist IV
Control Line RB
Offline Keith Miller
« Reply #8 on: October 22, 2015, 06:07:23 AM »
Are these CL versions timed the same as the RC version?
« Reply #9 on: October 22, 2015, 07:23:34 AM »
Yes. Just swapped the carb for a venturi.
Mr. Bob
Countyline Hobbies
Grovertown, IN.
574-540-1123
Online Motorman
« Reply #10 on: October 22, 2015, 08:09:14 AM »
What's the difference between RC and CL timing?
« Reply #11 on: October 22, 2015, 10:02:54 AM »
   No difference, one would hope.
Offline dennis lipsett
« Reply #12 on: October 22, 2015, 10:08:53 AM »
There is no difference  between either application in the Sportster line. None of them are particularly high rev engines and the timing is therefore mild. They did whether used in R/C or C/L behave more like a 4 cycle and were partial to using larger props than similar sized engines. The 28 does particularly well on 11 inch props and they are not adverse to having a little extra pitch if you need it. I generally used a TT 11/4.5 prop with excellent results. When propped accordingly they are really fuel efficient. The only downside is that they, like the Fox 35, require a controlled break in as they do not perform well till they get a reasonable amount of running on them.
Dennis
« Reply #13 on: November 08, 2015, 03:35:10 PM »
Will these be cheaper on Black Friday weekend?
Mr. Bob
Countyline Hobbies
Grovertown, IN.
574-540-1123
Like us on facebook
« Reply #14 on: November 08, 2015, 03:44:49 PM »
Are you serious?
Dwayne
« Reply #15 on: November 08, 2015, 03:52:03 PM »
Hi Bob, what size venturi do they come with.
Thank you
Dwayne
Dwayne
« Reply #16 on: November 08, 2015, 04:03:26 PM »
Dennis
This is great info, I've been playing with one, it has a 281 venturi and a OS 15 needle, I'm using a a power point 10/4 and it always wants to run flat out, so maybe a smaller venturi and a 11/4?
thanks
