Hi Mike,
As Ty says, apply it dry to open bay areas, it is VERY fragile when wet. Just pull it taught and get out all the wrinkles you can, dope around the edges and shrink with rubbing alcohol. I do the same thing Ty does on solid areas except I also apply it dry. Shiny side out. I do use shrinking butyrate for a couple coats after it is applied just like silkspan.
