  • July 06, 2025, 05:05:04 PM
Author Topic: Wing rod size  (Read 2085 times)
Offline sadams714441
Wing rod size
« on: November 06, 2015, 06:53:37 AM »
Wondering what size Rods to use when using rod method. I know the hole size from
Ribs from brodak are 5/32. Having hard time finding rods
Steve Adams
Offline Dick Pacini
Re: Wing rod size
« Reply #1 on: November 06, 2015, 07:00:45 AM »
That's strange because the Brodak Wing Jig Kit uses 5/16" rods.  You would think that any ribs they sell would be sized for their kit.
AMA 62221
Offline Larry Borden
Re: Wing rod size
« Reply #2 on: November 06, 2015, 07:01:05 AM »
I got my rods from ACP Composites.
http://www.acpsales.com/Carbon-Fiber.html
I also use carbon fiber arrow shafts.
Re: Wing rod size
« Reply #3 on: November 06, 2015, 09:00:37 AM »
5/32 is easy to find.  Its the 5/16 tubing I can't find locally.   I can see it now the postal lady carrying a package of 5/16 tube about 5 foot long.
Offline pat king
    • PDK LLC
Re: Wing rod size
« Reply #4 on: November 06, 2015, 09:41:02 PM »
Most of my ribs have holes for 3/16 music wire. You are limited to 36" music wire, but that isn't really a hindrance in building a straight wing.
Pat
Pat King
Monee, IL
AMA 168941
Offline builditright
  • So happy to be alive!
Re: Wing rod size
« Reply #5 on: November 07, 2015, 11:24:22 AM »
If they are 5/32" and approx. 2" apart they could have been set for the old adjust-o-jig
Thank you and God Bless
Walter
aka/ builditright
Re: Wing rod size
« Reply #6 on: November 07, 2015, 11:32:15 AM »
The ribs on my Brodak Legacy have 5/16" holes.  5/16" is within .003" of 8mm, so just get some 8mm OD carbon fiber tube from a kite shop and have fun.
If they truly are 5/32" then use music wire and support in the middle so that it stays straight.
Offline Daniel_Munro
Re: Wing rod size
« Reply #7 on: November 07, 2015, 02:40:13 PM »
I don't know what's available in the USA but here in NZ I used some contrete reinforcing steel in a jig I made up when I built my Brodak Legacy. It needed a slight clean up with some sand paper but was night and straight and very cheap.
NZL7396
Re: Wing rod size
« Reply #8 on: November 07, 2015, 03:22:41 PM »
Here's a post from my (suspended :( ) Legacy build showing the wing jigged up:
http://stunthanger.com/smf/index.php/topic,38062.msg390234.html#msg390234
Re: Wing rod size
« Reply #9 on: November 08, 2015, 06:59:41 AM »
Sorry guys meant to write 5/16
Steve Adams
Offline Dave Harmon
Re: Wing rod size
« Reply #10 on: November 08, 2015, 07:45:13 AM »
I did the same thing except I used large aluminum 90 degree angle available at Lowes, Home Depot etc.
I cut 2 pieces...cleaned up the edges then zapped them together back to back.
Then drilled the holes for the dowels at the same time to ensure they were in the exact same spot on the angles.
Next I marked the same end of the angles to identify the orientation.
Then I knocked them apart and zapped them into position over the plans on the building board.
My building board is a Blanchard ground piece of steel channel that is definitely flat.
Works great!!
